Need blinker control help!
Old Sep 3, 2006 | 02:24 PM
68RATVT's Avatar
68RATVT
Default Need blinker control help!
Anybody have a cure for all four tail lights flashing when blinker control moves slightly? Before you say replace module and harness,already did,twice, second was a Delco NOS. Thought it may be an open ground, couldn't find any. Replaced the blinker/hazard relays, checked connections. Seems to be the switch itself, if the blinker plastic contact moves off center slightly, all four lights flash through relay...
Old Sep 3, 2006 | 03:38 PM
noonie's Avatar
noonie
What does replaced module mean? What part?
Old Sep 3, 2006 | 03:40 PM
7T1vette's Avatar
7T1vette
Sounds like the blinker (safety flasher?) switch itself might have failed.
Old Sep 4, 2006 | 12:12 AM
68RATVT's Avatar
68RATVT
Default Blinker issues
The module I mean is the actual turn signal/hazard switch ring in the steering column. I changed the blinker relay and changed the switch twice.
To Need blinker control help!
