Re-doing shops work
A couple of years ago I start looking for a shop that could finish the car, at the time had no garage just an open barn to work in. Research around and find this recomended Vette expert in SoCal,6 hours from me
(Yea, I know, it should have never left the barn!Stop yelling at me.)To make this long story shorter,after 9 months I get my baby back, that was June and I'm still re-doing the half *** work. I sent the guy a rolling chassis, undercarriage and almost all motor compartment done. Needed interior,paint and misc.
I sent him a email after having her back, see below.
Below is a list of whats been found so far:
1; 375.00 to polish the paint, 7 big areas still were wet sanded, I could see them on the shipping truck before even being unloaded. Spot painted a complete missed area on driver rear fender lip. Sloppy!
2; no interior lights worked, repaired.
3; one tail light worked, no brake lights, one front running light out(not plugged in),national backorder on the blinker assembly huh,took me 3 days and he had no idea what backorder. repaired.
4; 7 interior screws missing,most from t-top area,very visible,and an extra screw drilled through a panel to hold it rather than taking apart and doing it right. Didn't I pay you 2000.00 to put the interior together?
5; Drivers side door must be slammed shut,you said just rubber breaking in, wrong, my new door panel was not put on right and the metal tab is broken off. Now I have to buy another panel and have the custom leather insert put in. Quality!
6; Had to replace hood release cable, it broke, thats strange because I had a new one you were to put on. That was alot of fun getting the hood open, your ears should've been on fire.
7; Lets not forget the antenna left dangling in the fender well, that's fun installing after the mufflers are in place.
8; Put real tips on rear exhaust after cutting that 7 inches of okie pipe hanging out, what the hell was that, I've never seen a vette like that.
9; Had motor tuned by a professional,not by ear, 6 degrees out and had to replace 2 plug wires,they were installed against the headers. Those are bendable boots, so you could have avoided that dumb ***...
10; the stereo bounced in the dash, the rear stabilizer bracket was not installed. repaired.
11; This however has got to be the best! Did you check the headlights? Did you rebuild or replace the vacume acuators like I paid for? Cause the passenger light jambed going up or down, kept getting hung up. Why, well, when I got down underneath to see, it was easy to fix, just cut off the ZIP TIES holding on the Fu*&^%$ grills, forget about any brackets or screws.
12; Oh, dont forget about the interior plate not installed, just a minor thing,thank god I got it back. Where are my nose/hood original flags? Since there not on the car?
13; The air cleaner covers you sent were both remakes, where's mine, factory original does not mean after-market piece of ****, so find it and send it back.
14; Good call letting you put on a "real good" alternator for 125.00, that junk Kragens 50.00 rebuilt peice went out.The belts were not even routed correctly,so the wrong belt was on it,did anybody notice it squeal? No, that would have taken effort.
15; cleaned out sandpaper and sanding dust from dash and rear compartments, I did not need extra..
It's looks like you just don't care about quality, it wasn't like I was going cheap, or was hard to get along with, or didn't give you enough time. You where so worried about being a star on Overhaulin you threw my car together. Terrible job superstar!
END-
Here's the email he sent back;
I wish I new you were having problems, I will always help you.
This is the first I have heard of your situation.
Remember you brought me a primered up car with all kind if hidden problems and
all the parts in a dozen boxes that you thought just needed to be put on.
That is were the fun began.
You know there was 3 steps forward and 1 or 2 steps back!
When a corvette comes in boxes it's 3 times longer, harder and more expensive every time!
Wrong parts, missing parts non fitting parts and yes parts on back order.
Bring it back and I'll help with the finishing touches.
If you don't ask I will never know. A project like that is impossible to put together
and never have to adjust or redo some things. I told you to get the leak fixed and plan on brining it back!
I won't go down your list of 15 because some of them may have been overlooked,
but we could have talked about them and we still can if you want to call me tomorrow.
END-
So are house was built and I have a great garage to work in now. Last night we installed the rocker panels correctly,after being painted, they were still raw! Just frustrated at the little things...Thanks for listening...
b
On a side note, the time to email him and complain about the problems he left you with is not after you fix them. I know he stiffed you but you could have given him the chance to pony up and make it right or refund you some of your money. If you didnt want him touching your car again and wanted to fix it and just let him know how much he screwed up then I understand.
