82 rearend problem
Old Sep 12, 2006 | 04:50 PM
JaxFl82's Avatar
JaxFl82
Default 82 rearend problem
When on the gas hard, around a corner, I’m getting a ratcheting vibration that resonates through the car. Obviously coming from the rear-end. This is of particular annoyance since less then a year ago I dropped a wad of cash having the rear-end rebuilt. Any ideas what's causing this? Any help is greatly appreciated! Thanks much - Yancey
Old Sep 12, 2006 | 08:24 PM
JaxFl82's Avatar
JaxFl82
Default Ummmm
Anyone?
Old Sep 13, 2006 | 01:20 AM
Steve COSD's Avatar
Steve COSD
Could be the clutches in the rearend or maybe a u-joint on one of the halfshafts. Does it do it when turning slowly right or left? Maybe they didnt add the lubrication additive to the rearend.
Old Sep 13, 2006 | 04:39 AM
Bob Onit's Avatar
Bob Onit
Ask the mechanic if he added the GM limited slip additive
If not it can feel like the rear is falling apart
$8 fix
Old Sep 13, 2006 | 07:06 AM
JaxFl82's Avatar
JaxFl82
Default Hmmmm..
Steve - now that I think about it, I seem to notice it more during turns to the left. Matter of fact..it also seems to be worse on left hand turns, hard on the gas, when the road has a bit bank the wrong way (as in road is a little bit higher on the inside of a left hand turn).
I'll also give the guy that did the work a call and find out if the additive was added.
Thank you both for the replies!
Old Sep 13, 2006 | 11:11 AM
Lon Wayne's Avatar
Lon Wayne
Default Scarry rear end noise
Had the same problem with my 77 and added the GM Lube . Noise left and even did A high speed auto cross at Mid Ohio Race Course(With Troy Corvette club), The rear end did great.Add the Lube!!!!
Old Sep 13, 2006 | 12:19 PM
3rd_Vette's Avatar
3rd_Vette
About 12 years ago, my 80 did the same thing. I was on a visit to see my dad in Las Vegas and the first day I was there, it started. I took it to 3 places and the trans shop thought it was the trans. (duah). The next guy thought it was the rear end, then I went to the dealer and they said to leave it a few days and they would figure it out. I drove back to Northern California and the next day, I left it at my regular service shop. I got a call within the hour stating that my u-joints in the 1/2 shafts were bad. All were replaced and no more problem. At that time, the car had about 50k easy miles on it.
Good luck.
Old Sep 13, 2006 | 08:28 PM
JaxFl82's Avatar
JaxFl82
Default Well....
I guess I'll try the low dollar fix first and and add the lude.
Thanks again all.
Old Sep 13, 2006 | 10:30 PM
Clint's C3's Avatar
Clint's C3
I'd inspect the u-joints while you are under there.
Old Sep 13, 2006 | 10:39 PM
JaxFl82's Avatar
JaxFl82
Will do! Be under there installing my VB and P Smart Struts this weekend anyway.
To 82 rearend problem
