just wondering if you guys have opinions on sidepipes. are they worth it or not? and if so any brand reccomendations??...believe it or not my 73 has a juiced up 327 in it not the 350/454, i bought it that way....soooo i dont know if that can sway your opinions but i just wanted some info on sidepipes, cost, brands etc. i really like the way they look.
yeah ive been reading people are conflicting reports here of power loss/gain so what IS THE DEAL?? or are these assumptions restricted to certain brands or set ups? to be honest my cars 30+ years old i drive with it easy so if im gonna lose some power for better looks and sound than thats ok with me....
Deal is '69 OEM sidepipes w/ original muffers are restrictive.
Hooker/Stahl, etc side mounts flow REALLY well if you use an appropriate muffler/baffel, or open headers.
all the l-88 race cars where hollow sidepipes no guts to them,and that was a differnet time,the exhaust systems back then weren't like they now.
A member here dyno'ed his car with open Side mounts vs JCL inserts (baffels) and the difference as a mere 12hp.
The L88's still managed some 600hp+ in race trim w/ the side mount headers, so if they are restrictive they still get the job done. Almost every race car to some extent has exhaustr exiting from the side including the C5/C6R race cars. While the may not have a radical bend they aren't 100% straight and do have to make 45-90 turn to exit out of the side. The added benefit is added ground clearance.
A couple of key words here--OEM side pipes (very restrictive) and "simulation". In the real world, side pipes with good mufflers or inserts are less restrictive=more hp. I love my Hookers, and I can definately feel more hp then the stock under body system. Also, exhaust heat goes around the body, rather then up through it. A real advantage.
L-88 race cars don't run inserts so it's all open header.
Dynoing a car with sidepipes open and with inserts may only have a 12hp differnce and jcl inserts are more to kill sound db's at a race track,but if you compared sidepipes to a full exhaust on street car,there is proven losses,Plus a 600 hp race engine isn't going to be very differnet.my 706 made 1058 hp with open headers and 1030 with flowmaster race mufflers.
I just think if you are going for look then there great,if you are horsepower hungery they aren't the trick deal
I guess like everything else in life, this is relative and depends upon your perspective. If you take a 75 w/the stock 2-1-2 exhaust, I'd bet any sidepipes were less restrictive. However compared to a well constructed 3" pipe full dual exhaust, then perhaps they are more restrictive.
So my reply to this question is yes .......... and no.
Dynoing a car with sidepipes open and with inserts may only have a 12hp differnce and jcl insets are more to kill sound dbl's at a race track,but if you compared sidepipes to a full exhaust on street car,there is proven losses,Plus at 600 hp race engine isn't going to be very differnet.my 706 made 1058 hp with open headers and 1030 with flowmaster race mufflers.
Yellow? That you? Some of those misspellings look very familiar...
Real Side Pipes such as HOOKER will flow as well as an under car exhaust system if you use a good flow through muffler system such as the STS Baffles. Now by using such a baffle system it will sound louder to the occupant of the car simply by the location of the exhaust outlets and how the baffle works where as an under car system transmits the exhaust all the way to the back through a muffler and then past the car which gets the sound effects further away from the occupants.
Another item that has not been mentioned is the fact that if you run side pipes it will help in a couple of areas one of which is to help keep under car temps down thus lowering the temp inside of the car and floor board areas for the occupants. Second that it will unclutter the underside of the car and make it easier to do repairs without the exhaust system in the way.
And what may I ask is this 706 in Who built it and location?
hi doing frame off an i got manifolds ported smoothed with sweet thunder side pipes better flow but not stall or hooker but cooler an less pipe to deal with an its a 73 have fun do what you like .
A pro street 37 ford coupe,I built it.used to race the car,and this winter turned back a street only car,I had the motor so I took it part freshed it and detuned it a little.
I'm in missouri
