I finally completed the drawings for the Body Dolly I built. It was for a 1969 Coupe.
A few of you requested a copy - so its ready. Click on the preferred link and 'saveas' to your drive.
NOTE: If someone is interested in creating a compete list of tasks in sequential order to enable removal and re-assembly of body, I will add to this drawing. Just let me know.
UPDATED: 2006_09-16 Updated Vert Post Dimensions and correlated these dims to the AIM Arbitrary Frame Basis Line (Datum) UPDATED: 2010_07-09 Updated links to PDF's ALSO BE ABSOLUTELY SURE TO USE THE FRONT BRACING (Area A) UNDER THE CORE SUPPORT !!!!!!!!!
The surround panel is extremely fragile. IT IS IMPERATIVE !!!!
Will add to next update:
AIM = Assembly Instruction Manual (Chevrolet Motor Co) w/all parts and numbers and sketches
The 4' x 4" 'stubs' are short pieces of 4x4 that are used to give more support.
Get a more accurate count of bolts/lengths from CF members. Can someone assist?
Add a sequential list of items required to be reomved to remove body. Can someone assist?
3 body mount bolts and my 69 coupe is ready for a dolly. Bought the casters last Saturday. Got some frame repair / replacement scheduled. The timeliness of your post couldn't have been better. Thanks again.
I don't know if an engineer would refer to it as "plan view" and "elevation view" though. Either way, the drawings are excellent.
I work in the engineering world. Plans and elevations are commonly used in assembly drawings like this. Kaiserbud has done a very professional job in preparing this drawing. Obviously he has been in the business for a while!!
You da man.
I was just out in the driveway measuring up the car and comparing to other body dolly drawings.
Will be going to home depot tomorrow and getting the materials outlined in your drawing and building it. Hopfully I can find a bunch of buddies this week or next sat to lift the body.
-Brett
Hi KB,
This is the first time I've seen your plans for a body dolly.
Your original posts were a little before my time so I missed them.
Nice!!
Regards,
Alan
