Stinking battery
Old Sep 25, 2006 | 05:30 PM
  #41
Bob Onit's Avatar
Bob Onit
Originally Posted by gator79
how did a disconect cause a fire?
Gator
This was 20+ years ago but I still remember one like it was yesterday
1978 Autocar 350 HP Cummins Diesel
4 12V batteries in one box
It was a thumb screw type switch which had failed ( Much more heavy duty than the ones I have seen posted for the Corvettes)
Due to the quality of the switch it kept making and breaking the ground contact while on the road.
Basically the sparks from the contact caused the batteries to explode and caused the fire.... New cab/hood/wiring all interior... and it was never the same after that
Second case was the same switch, same issue but this was a Ford Diesel, but this time the vehicle was not saved.
Twin batteries in one box....... burned to the ground on the side of the road......
No Fire extinguisher will save a car/truck from 4 or 2 or even one fully charged battery unless you have a good pair cable cutters and you can get access to the cables without getting burnt
We then switched to the larger more dependable ( more expensive ) switches which I have posted a few times.
1 2 or 4 batteries equals disaster in an enclosed area with a cheap switch......... just my opinion ... of course, I have seen it first hand
Old Sep 25, 2006 | 07:50 PM
  #42
Durango_Boy's Avatar
Durango_Boy
A buddy of mine lost a boat to a battery fire. He ended up using the marine 350 for a bouy anchor after that. Did I spell either of those last two words right?
Old Sep 30, 2006 | 10:56 PM
  #43
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Update. Now only $2.99!
Originally Posted by cardo0
I just saw that switch at HF today Gordomn for $5.29. This may rattle a few cages but so be it. I had to control myself not to buy it as i don't have a drain problem with my Optima. I've been training myself to just keep moving - no stop - when i see something i like at HF but don't really need.
cardo0
I can't take this anymore, now i have to buy at least 1. Hobo Freight has them on sale for only $2.99! Just got thier flyer today - item #92688-2ASB, 100 amps continuous w/1000 amps surge.
BTW there's nothing to short to ground in a vettes fiberglass batt box.
cardo0
Old Oct 1, 2006 | 12:58 AM
  #44
Chris Farrer's Avatar
Chris Farrer
I like the battery disconnect switch and has worked well on the vette and the boat. It not only cuts all drain from the battery but is an additional security device because you can remove the ****. I know you can hot wire blah blah blah, but it's just one other measure.
Old Oct 1, 2006 | 08:55 AM
  #45
Durango_Boy
Gotta love Harbor Freight. I bought a full tap and die set, high speed steel, for $20. I've used it several times now and how found no dulling or snapped taps.
Old Oct 1, 2006 | 08:43 PM
  #46
gte718p's Avatar
gte718p
Originally Posted by Durango_boy
I have a solar one, but it never seems to work...and I've heard they don't have an auto shutoff and can over charge the battery.
Its not possible to over charge. They have a 13 volt regulating diode on them. Its apretty dumb system, but it works. The cells always put out 13 volts. As the battery approachs 13 volts current goes to 0. It is a painfully slow way to get a charge flow.
Old Oct 1, 2006 | 09:01 PM
  #47
Durango_Boy
Hmm, well cool. One less thing to worry about and chalk up to myth.
Old Oct 1, 2006 | 10:30 PM
  #48
justaguy10825's Avatar
justaguy10825
Battery cut off switches are great as long as you don't mind re-programming your stereo everytime you go for a drive...
Old Oct 1, 2006 | 10:38 PM
  #49
PRNDL's Avatar
PRNDL
That's why they make them with a little thin wire and a little fuse. Enough power to keep your radio programs but not enough to start the car or quickly drain the battery or start a fire.... hopefully.
Old Oct 1, 2006 | 10:59 PM
  #50
Gordonm's Avatar
Gordonm
What is a stereo? I have 2 pipes that give me stereo!
Old Oct 2, 2006 | 06:41 AM
  #51
73jst4fun's Avatar
73jst4fun
Old Oct 2, 2006 | 09:35 AM
  #52
Durango_Boy
Another option is wiring a small 9V battery to the stereos hot and ground wires. Add a diode so teh 9V can only go one way into the stereo and not backwards into the rest of the system. It'll be the only thing with a power source, and the rest of the car will remain 'dead.'
