I did on mine awhile ago. Not too bad if you got a small hand!
Not bad even with big hands
I think I did it in less than 30 minutes
I re-indexed my distributor so the new one will hopefully last many years
Dont forget cable lube or you will be buying another one soon
Do you have to disassemble the dash to change the cable?
Bill
NO
I just removed the AC ducts
You can get your hand back there........its just a spring clip that holds it in.
It's much easier to get the old cable off with a helper gently pulling on the cable from the engine compartment while you push the clip in.
It pops right out
