1976 Engine Block ID
Old Sep 28, 2006 | 09:11 PM
Runnik's Avatar
Runnik
Default 1976 Engine Block ID
Hey all, I am reletivly new to the car fixing world. I need to know if there are any sites that have a database for engine block ID's or if any of you know what the block ID number for a '76 is.
Thanks.
Runnik
Old Sep 28, 2006 | 11:20 PM
Tom73's Avatar
Tom73
http://www.corvetteactioncenter.com/...976/index.html
Old Sep 29, 2006 | 08:38 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
All Vette 350's both L82 and L48 were block casting number 3970010,
and both L82 and l48 had head casting 333882
(compliements for Corvette Black book)
Old Sep 29, 2006 | 09:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the numbers on the pad on the block at the front of the right head. You may need a flashlight to see and can expect to have to scrub off some road gunk. The pad is stamped with the engine identificaiton code and a VIN derivative of the vehicle the engine was originally installed in. The ID stamp will give you more specific information than the block casting number.
Old Oct 2, 2006 | 08:44 AM
ruby76's Avatar
ruby76
No, the block "casting" number on all 76 Vettes is 3970010, the Serial/identification number is what you are describing with the VIN etc. on the stamp pad. The casting number is on drivers side rear flange where the tranny mounts.
Old Oct 2, 2006 | 08:57 AM
Easy Mike's Avatar
Easy Mike
I understand that. I'm betting he wants more specific information than just a block casting number.
To 1976 Engine Block ID
