Push Or Pull
Old Sep 30, 2006 | 09:53 AM
SPIKESDAD's Avatar
SPIKESDAD
Default Push Or Pull
Thinking Of Changing Out The Fan On My 78-currently Has A Push Fan With Clutch {that Rattles Until Its Warmed Up A Bit}
Any Suggestions ??
Old Sep 30, 2006 | 10:18 AM
MN80Vette's Avatar
MN80Vette
I got rid of my engine fan and replaced it with a puller. It had no problem keep my GM crate engine cool while idling around the Car Craft Summer Nationials car show on a hot summer day.
Old Sep 30, 2006 | 10:19 AM
rihwoods's Avatar
rihwoods
Any Suggestions ??
Do you mean the fan clutch is loose or wobbling? Because if it is,you should also replace your water pump as well,as they share the same shaft.....and your pump will go next..
Rich
Old Oct 1, 2006 | 09:03 PM
SPIKESDAD's Avatar
SPIKESDAD
no its all solid
Old Oct 1, 2006 | 09:16 PM
...Roger...'s Avatar
...Roger...
Any Suggestions ??
You must mean a pull fan with a clutch-that rattles
Suggestion-replace the clutch(and the pump)
Old Oct 1, 2006 | 09:29 PM
rihwoods's Avatar
rihwoods
Not understanding this...so what "rattles"...???
Rich
Old Oct 1, 2006 | 10:03 PM
Vettkeeper's Avatar
Vettkeeper
If it's a stock 78 fan than it is a pull fan, and you will need to replace both the water pump and fan clutch. Also while you have it apart check the fan blades for cracks. Replace the fan if you find any cracks!!
Old Oct 2, 2006 | 09:28 AM
SPIKESDAD's Avatar
SPIKESDAD
The Fan Thats On It Is A Push Fan ! The Noise {rattle} I Hear Is Only Heard When Its First Started. After Its Run For A Minute Or Two It Goes Away. It Only Does It When Its First Started And Never When The Engine Is Warm.
Old Oct 2, 2006 | 10:12 AM
...Roger...
Are you absolutly sure its pushing air through the rad to the front of car or "pulling' air from the front towards the rear ? If it is pushing air from the engine side through to the front then you have the wrong fan blade on the car.
Old Oct 2, 2006 | 10:15 AM
...Roger...
Suggestion--replace fan ,fan clutch and water pump.
Old Oct 2, 2006 | 12:40 PM
SPIKESDAD's Avatar
SPIKESDAD
I Smoke--the Smoke Goes To The Front. Any Great Need To Have A Clutch Anyway ???
Old Oct 2, 2006 | 01:35 PM
norvalwilhelm's Avatar
norvalwilhelm
Any Suggestions ??
I never heard of a mechanical push fan. All mechanical fans pull the air through the rad. If it is electric it wouldn't have a clutch.
If you are going electric you want a puller, They are more efficient and you will run into problems with a fan infront of the rad. When you open the hood it will hit the fan.
That said I run both. A puller behind the rad and an electric pusher in front
Old Oct 2, 2006 | 01:39 PM
rihwoods's Avatar
rihwoods
What were you smoking ???
Old Oct 2, 2006 | 01:45 PM
big_G's Avatar
big_G
OK, now I'm more confused than usual. And please explain why every word must start with a capital letter?
Old Oct 2, 2006 | 01:47 PM
...Roger...
Was he raising his voice ?
Old Oct 2, 2006 | 02:59 PM
Durango_Boy's Avatar
Durango_Boy
Why is everyone yelling? I don't know what we're yelling about.
ORIGINAL POSTER - You're a cig smoker. You're saying, with you leaning over the fender, and smokeing, that the second hand stuff that's giving me lung cancer is being pushed through the rad towards the nose of the car?
If this is true, you have two problems, and not just one. The clutch is bad, and may have damaged the water pump. The other problem is fan pitch. Can you take a few pictures of the fan while it's NOT moving? We can tell you if the blades are incorrect or not.
Old Oct 2, 2006 | 03:42 PM
SPIKESDAD's Avatar
SPIKESDAD
That Right Don't Stand In Front--cause Thats Where It Goes-its Apparent That At Sometime The Front End Has Had Some Damage And Had Been Repaired. And The Old Farmer Who Owned This Car Could Have Done Anything--so I Will Go To A Pull Fan,the Way It Should Be.
To Push Or Pull
Old Oct 2, 2006 | 03:43 PM
SPIKESDAD's Avatar
SPIKESDAD
Naw--gave That Up Back In The 70's
Old Oct 2, 2006 | 03:47 PM
Durango_Boy
Forgot to capitalize this one...
Old Oct 2, 2006 | 04:00 PM
jackson's Avatar
jackson
Spikesdad:
Within the last coupla weeks ... there was a post from a fellow who put up pics of very nice looking engine bay ... and then someone noticed that the fan blades had wrong pitch (WAY wrong) ... sure enough, he had an aftermarket Vbelt-driven, waterpump-mounted fan on it and the blades were made for reverse rotation. The Vbelt-driven, waterpump-mounted fan on a vette is designed to pull air from front of car through rad and into engine bay. If yours ain't doing that, it's wrong and it cannot efficiently cool.
