engine ID pad (pic)
Old Sep 30, 2006 | 07:46 PM
LT4Coupe's Avatar
LT4Coupe
Default engine ID pad (pic)
How does this look? Its from a 71 on EBay. I'm not looking
to buy, just to increase my knowledge
Old Sep 30, 2006 | 08:33 PM
c3dreamer's Avatar
c3dreamer
See this:
http://vetteworks.tripod.com/1971SPECS.html
That Vette should have a 350 c.i., 270 hp engine with manual transmission.
Old Sep 30, 2006 | 08:35 PM
c3dreamer's Avatar
c3dreamer
Originally Posted by c3dreamer
See this:
That Vette should have a 350 c.i., 270 hp engine with manual transmission (CJL Code).
Production car number: 10,018
Old Sep 30, 2006 | 10:58 PM
Mike Ward's Avatar
Mike Ward
It really doesn't matter what's there now, that's possibly a restamped pad, and not a very good one at that.
There should be no 'grinding marks' going from side to side on a pad .
Old Sep 30, 2006 | 11:47 PM
LT4Coupe's Avatar
LT4Coupe
What is really "throwing" me, is the c at the begining of the
vin sequence. I notice that some 71s have it, and some don't.
I'm starting to think it was only used on early 71s.
Very confusing!
Old Sep 30, 2006 | 11:55 PM
Z-man's Avatar
Z-man
No way those numbers are legit. Are you sure it's not an '81?? It's probably an engine from a passenger car.
'71s Serial Numbers: 194371S100001 through 194371S121801
Here's what a '71 should look like:
DZRick's Avatar
DZRick
Could those (grinding marks) actually be sanding marks, it looks like the guy sanded the paint off to allow pictures to show the numbers.
I'm just asking.
Rick
Old Oct 1, 2006 | 08:28 AM
Mike Ward's Avatar
Mike Ward
The pad was not painted to start with, so there would be no need to sand it. If the owner was trying to make it pretty and shiny, he screwed himself good.
Old Oct 1, 2006 | 09:09 AM
mstanton's Avatar
mstanton
For 1970, pad stamps were 70S4XXXXX. For early 1971, stamps continued with the same format, 71S1XXXXX. Starting in Sep 70 sometime 71s changed to C11S1XXXXX. That would be correct for this car. I'm no expert and it's tough to tell from pictures. My guess is that the side to side is from sanding and I'm voting for it's original.
Old Oct 1, 2006 | 09:41 AM
Carl Granquist's Avatar
Carl Granquist
I have good reason to believe mine is original, but repainted just before I bought it. So, my pad has a nice glossy orange coat of paint. I can read the numbers clearly though. If I wanted it to be "correct" then how would a person go about removing the paint and not leave scratches, etc.?
C11S114491 V0330CJL
Old Oct 1, 2006 | 10:47 AM
Mike Ward's Avatar
Mike Ward
Paint remover! If it's really thick and stubborn DOT3 brake fluid will do the trick. Be very careful as it it will eat any paint anywhere!
Old Oct 1, 2006 | 02:23 PM
DZRick's Avatar
DZRick
It is obvious from the paint shown in the groves in the numbers that someone repainted the motor.
In my humble opinion that pad is original as are the numbers stamped on it.As to whether it is from 71 vette, I'll leave that to the numbers guys.
Try the NCRS.
Old Oct 1, 2006 | 02:33 PM
Red70vette's Avatar
Red70vette
Pad looks good to me. Obviously painted at some point and perhaps the paint was removed with sandpaper. The CJL code after the second set of nukmbers indicates that it is a base engine 350 270 HP with a Rochester quardrajet and a 4Speed. This is typically not the engine combo you would want to fake with such a high caliber stamp. There is just not enough money in the base engine option. If it was a big block I would be a little more concerned.
Old Oct 1, 2006 | 06:00 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Default MORE #'s TO LQQK AT
Here Are More #'s To Lqqk At:
click Here >>>>>>>>>http://forums.corvetteforum.com/show....php?t=1513306
Old Oct 1, 2006 | 06:02 PM
c3dreamer's Avatar
c3dreamer
and check also here:
http://forums.corvetteforum.com/show....php?t=1333858
and check this site:
http://rowleycorvette.com/stats71.html
Your engine should have also the numbers 3970010. That imply a 350 c.i. engine. CJL code are only for 1971 Chevrolet 350 c.i. engines.
Old Oct 2, 2006 | 09:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There was a strike at St. Louis from about mid-September 1970 through nearly the end of November. My finacee's '71 got caught in it. Casting numbers and VIN all point to what should have been a late September build date, but her car ended up with December 1 build date due to the strike. Her block is not stamped with a "C" code. After the strike, '71 blocks began to be stamped the with "C" characters. The '71 Registry has additonal information regarding block stampings. The NCRS Judging Manual also helps.
Old Oct 2, 2006 | 11:47 AM
Z-man's Avatar
Z-man
Aha! So that's why there's confusion. Good info...
To engine ID pad (pic)
Old Oct 2, 2006 | 09:00 PM
Amature's Avatar
Amature
I have a similar question on my 1970. What does the V0202CTD indicate on the engine pad besides 350, 300hp? Also what does Chevrolet 828 mean on the VIN plate? Thanks.
Old Oct 3, 2006 | 03:18 AM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Old Oct 3, 2006 | 08:12 AM
Easy Mike's Avatar
Easy Mike
PM sent.
