The Aim Manual Says That You Have To Drop The Column And Also There Is A Ground Wire In That Area On The Switch. Do Mark The Two Hoses, Good Luck , I Have Just Ordered My Switch To Install From Ecklers. I Was Told At The Local Gm Dealer That Mine Is Obsolet. I Have A 73
Noobs to the vintage truck scene can never figure out how to get the switch out of those steel dashboards. It's kinda funny.
I know, the '73 Scout II I had was cut up. Someone obvisouly thought cutting the dash around the switch **** would get it out but I have no idea how they had planned to put it back in. It had a patch riveted in place iover the hole, and the switch was dangling behind on the wiring.
