OT: Need a Plumbers Advice
Old Oct 4, 2006 | 08:13 PM
blueray72's Avatar
blueray72
Default OT: Need a Plumbers Advice
Thought I'd ask the C3 experts for my home plumbing issues
I'm working in the garage and notice a stain on the ceiling. I assume I've got a leak in the roof. I get up in the attic and find a leaky copper pipe. (Sorry no pics--not so easy to get up in there to take a pic). It's the main 3/4 feed to the house from my outside spigot and reg. It's been repaired before for some reason--there's a coupler.
My question..All around a 90 is green stuff, like what you see when you get electrolysis(?). Do I have more than just a leaky joint issue? I planned on resoldering the joint, but the green stuff has me concerned. I checked out my water heater and no issues there.
Old Oct 4, 2006 | 08:30 PM
JoeRags's Avatar
JoeRags
ever wonder why the statue of liberty is green?
thats what color copper turns when it corrodes.
cut out the bad coupler, and put in a new section of pipe with 2 new couplers... just solder it up good with some flux paste.
Old Oct 4, 2006 | 08:31 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
The green stuff is not an issue. get the water out, clean everything uo with scotchbrite or sand paper, apply flux and solder away. GL
Old Oct 4, 2006 | 08:32 PM
eastltd's Avatar
eastltd
The green stuff is likely just oxydation due to the old flux not being clean off the joint after assembly. Sweat the joint apart, clean it well and resolder. Make sure you clean the excess flux off after you're done and you shouldn't have anymore green.
Old Oct 4, 2006 | 08:50 PM
kona's Avatar
kona
Heres a cool little trick when soldering copper pipe. If the water continues to drip while soldering it will make for a bad joint so shove a piece of bread(small) into the pipe. Keeps the water from running out just long enough to get a good joint.
Dissolves and flushes out as soon as you turn the water back on.
Kona
Old Oct 4, 2006 | 08:52 PM
blueray72's Avatar
blueray72
Default why this board rocks?
Thanks everyone.
Makes sense that there's so much oxidation....and now a leak. Off to the store for some propane!!
Old Oct 4, 2006 | 10:06 PM
gator79's Avatar
gator79
I also like the bread trick
Old Oct 4, 2006 | 10:34 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Kona
You can get weird little plastic-ish beads in different sizes that do the same thing. Just apply some heat to the pipe where the bead is pressed in, and it dissolves.
Old Oct 4, 2006 | 11:57 PM
LittleJake's Avatar
LittleJake
Kona
My grandfather was a plumber and I used to help him during the summers before he died. This is an old school trick. Thanks for posting it Kona, made me think of some very fond memories. Very old school trick!
Old Oct 5, 2006 | 12:11 AM
hzz's Avatar
hzz
Make sure you take a spray bottle or some other source of water with you when you go up there to solder.
Better to be safe, than sorry!
Old Oct 5, 2006 | 12:36 AM
vetteaddic's Avatar
vetteaddic
They also have fittings called sharkbites, if you dont wanna solder ,cut the bad piece out and install a piece of pipe with two sharkbite couplings and be done.
Old Oct 5, 2006 | 01:15 AM
blueray72's Avatar
blueray72
got it...bring bread and water....oh and a beer!
Old Oct 5, 2006 | 03:07 AM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Originally Posted by Sunspot
Thanks everyone.
Not Propane use map gas.
Old Oct 5, 2006 | 03:11 AM
standup's Avatar
standup
Funny that nobody suggested duct tape....
Old Oct 5, 2006 | 03:14 AM
SHAKERATTLEROLL
At this time of nite lol. Bubba is drunk and passed out but I am sure he will chime in here lol.
Old Oct 5, 2006 | 05:25 AM
Bob Onit's Avatar
Bob Onit
Will an english muffin work?
Old Oct 5, 2006 | 05:34 AM
Bangkok Dean's Avatar
Bangkok Dean
Not if he's French
To OT: Need a Plumbers Advice
Old Oct 5, 2006 | 06:35 AM
mdj21's Avatar
mdj21
why MAP gas over propane?
Old Oct 5, 2006 | 07:30 AM
DR.Jay's Avatar
DR.Jay
It burns hotter so the solder melts faster from what the plumber I once worked for told me.
Old Oct 5, 2006 | 08:04 AM
mdj21's Avatar
mdj21
very interesting. did not know that. thanks.
