Bird dropping stain
Old Oct 15, 2006 | 12:26 PM
SmokinBBC's Avatar
SmokinBBC
Default Bird dropping stain
Not on my vette..
Left my DD in a parking garage at the airport while I was traveling for a couple of days...came back to a nasty dump on the hood...friggin bird must of had refried beans or something
Anyway, washed the car. I can still see a stain. What's the best way to get rid of it? The finish is black clearcoat.
Paul
Old Oct 15, 2006 | 01:03 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Originally Posted by SmokinBBC
Not on my vette..
Paul
A clay bar should work on that as long as it didn't bake into the paint. Another method is to use a vineager and water solution and soak the area. You could also try a little 3M polish with a fine grit to it and then finish with something like a wax or sealant to protect it if you got the stain out. Good luck.
Old Oct 15, 2006 | 04:19 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Or compound...
Old Oct 15, 2006 | 04:28 PM
robertmc48's Avatar
robertmc48
Veteran: Marine Corps
They are hard to fix. Bird poop is Uric acid. Once its had the chance to work all you can do is remove paint until it's smooth again.
Old Oct 15, 2006 | 06:15 PM
SmokinBBC's Avatar
SmokinBBC
Used Clay Bar...ended up doing the whole car...then polished...then waxed. The while your at it ended up taking the whole day!
Looks as if the stain is gone, but it's hard to tell in my garage and it's not bright enough out to see very well. I'll check in the morning.
Old Oct 15, 2006 | 06:32 PM
Jims79's Avatar
Jims79
Meguiars number 7 polish will get out the stain & leave the paint looking wet. good stuff
Old Oct 17, 2006 | 08:30 PM
SmokinBBC's Avatar
SmokinBBC
I used Meguires stage 1 polish and stage 2 wax. I was very impressed with the polish...but not the wax..seams to"smear" if it is touched (or walked on)...damn cat!
Old Oct 17, 2006 | 11:35 PM
cosmicvette's Avatar
cosmicvette
Once it has eaten through you are stuffed, I hope the clay bar works for you but.......................
Old Oct 18, 2006 | 12:55 PM
SmokinBBC's Avatar
SmokinBBC
it is gone...think it was a combination of previous wax coating, clay bar, polish and new wax...plus I got to it within a couple of days.
Old Oct 18, 2006 | 03:11 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
Glad to hear it worked
Old Oct 18, 2006 | 07:33 PM
SmokinBBC's Avatar
SmokinBBC
To Bird dropping stain
