Reverse Clock ??????
Old Oct 17, 2006 | 06:50 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Default Reverse Clock ??????
REVERSE CLOCK ??????
ever see an original vette clock go in REVERSE ? the sceond hand all of a sunnden went backwards for a few seconds, was having a starting issue, turned key & it did nothing, no click no nothing nada...........wiggled battery cables & it started, is this a lose cable ? ground issue ? what would make a clock go backwards, ever see this before ? once in a while the lights go really really bright & then very dim..........another time i turned on my headlights & the car shut off.........possible multiple issues ? dont want any electrical fires, alrady had one years ago in my yellow vette........still eating SULFER everytime i take it out.........!!!
ZIXXX PACKER
Old Oct 18, 2006 | 07:49 AM
427SIXPACK's Avatar
427SIXPACK
Default ttt
ttt any sugestions ?
zixxx packer
Old Oct 18, 2006 | 08:00 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...if you reverse the polarity, it'll run backwards.
Old Oct 18, 2006 | 08:23 AM
Secret Squirrel's Avatar
Secret Squirrel
ZIXXX PACKER
Did you check the odometer, maybe it was going backwards as well(christine style)
If the trend continues you may end up with a super low mileage 400/390hp tripwr, could get you a lot more bucks(you can smell bucks yeah?.....sorry, meant SPELL) ......................don't let it go to long though or you may just end up with a shell and no numbers to back up your find
Old Oct 18, 2006 | 08:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
ever see an original vette clock go in REVERSE ? ...
Yes. No problems after I cleaned my clock.
Old Oct 18, 2006 | 10:56 AM
vettfixr's Avatar
vettfixr
Mine does the same thing. Your clock may not be original. I converted mine to a quartz movement a few years ago and one of the things I noticed is that it will sometimes run in reverse. No big deal, you just disconnect the battery for a second and then reconnect and it will run correctly. You may have to do this 2 or 3 times to get it right. On the good side, its very accurate when it runs correctly. But even when it runs in reverse it's still right twice a day.
Old Oct 18, 2006 | 01:49 PM
427SIXPACK's Avatar
427SIXPACK
Default thanks
THANKS AS USUAL ANOTHER USELESS REPLY FROM THE SQUIRREL, DO YOU EVER POST WITH ASSISTANCE OR ARE YOU ALWAYS AN ***HOLE............. GO FIND A NUT & PLAY IN TRAFFIC
Old Oct 18, 2006 | 01:51 PM
427SIXPACK's Avatar
427SIXPACK
Default Not Quartz
THIS ISNT QUARTZ, IT'S THE ORIGINAL CLOCK & I'M ONLY SEEING IT GO BACKWARDS WHEN I TURN THE KEY I'M HAVING A STARTING ISSUE & IT HAPPENS AT THE SAME TIME........
ZIXXX PACKER
Old Oct 18, 2006 | 07:45 PM
jdp6000's Avatar
jdp6000
ZIXXX PACKER
It sounds like a bad ground on either the battery or alternator or main ground on the door pillar. Next time it happens wiggle things in order. Example wiggle the ground on the battery. If nothing happens wiggle the positive. You may be able to cause the symptoms by wiggling wires while the car is running. Try the ground on the battery then alternator. If it is neither there should be a main ground on the driverside footwell area...its up about 18 inches on the door pillar.
Actually I would check this door pillar ground first..ignition,lights,cluster etc is all grounded there. Mind you I'm not familiar with your car but from what i have read most C3's have this ground.
Jim
Old Oct 18, 2006 | 10:56 PM
427SIXPACK's Avatar
427SIXPACK
Default Thank You
Jim
I THINK IT IS A GROUND ISSUE.............THANKS
ZIXXX PACKER
Old Oct 19, 2006 | 08:21 AM
jdp6000's Avatar
jdp6000
Keep in mind solving the problem by wiggling the cables at the battery the last time does not mean thats where the problem is. You may have just shocked the system.
Jim
Old Oct 19, 2006 | 12:12 PM
427SIXPACK's Avatar
427SIXPACK
Default thanks
JUST DONT WANT TO GET STUCK ANYWHERE, I'LL HAVE TO HAVE IT ALL CHECKED OUT.........
ZIXXX PACKER
To Reverse Clock ??????
