Windshield washer pumps wont fire
Old Oct 23, 2006 | 04:48 PM
karioth's Avatar
karioth
Default Windshield washer pumps wont fire
The washer motor is new, wipers work but sprayers dont. Highly suspect the switch itself, is there an aftermarket switch? can the switches be cleaned? Anyone had to deal with this yet???
Old Oct 23, 2006 | 04:58 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I had to rebuild a couple of these pumps years ago. This babies are touchy and what you might have is an issue where the pump needs to be primed, but there is really no priming method. The two I have done we just had to keep hitting the switch over and over and eventually it usually starts. If I remeber right the pump actually works off of the wiper action and pumps from wiper action.
Old Oct 23, 2006 | 05:02 PM
corvetteload's Avatar
corvetteload
Don't laugh at this, but to prime the pump, put some water in your mouth and on the feed hose to the pump force water into it to the pump. This should prime it. Good luck................B
Old Oct 23, 2006 | 06:59 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Default Not Laughing But..............
NOT LAUGHING BUT
..............if your gonna put it in your mouth ya might as well try VODKA i'm certain it'll clean your windows & get you "PRIMED" at the same time..............
ZIXXX PACKER
Old Oct 24, 2006 | 02:08 PM
karioth's Avatar
karioth
Originally Posted by 427SIXPACK
NOT LAUGHING BUT
ZIXXX PACKER
hahaha
Old Oct 24, 2006 | 02:09 PM
karioth's Avatar
karioth
does someone have to hit the switch while you do this or are you blowing the water (vodka) through?
Old Oct 24, 2006 | 03:01 PM
Durango_Boy's Avatar
Durango_Boy
Most pumps will allow the fluid in the tank to drain through the pump via gravity. Disconnect the line so it's dangling from the pump...fill the bottle, and watch the water start dripping. Then just re-connect the line, and bingo - primed.
I suspect it's not the pump. They will run with no fluid. I suspect either a pinched wire or a bad switch. Have a friend operate the switch while you test the wires with a DMM and make sure you have 12V and a good ground. If one or the other is missing you may have found your problem.
Old Oct 25, 2006 | 11:55 AM
corvetteload
How can gravity work if most feed bottles are lower than the pumps?!?!?!?! Karioth, If you can remove the plastic cover from the pump, someone can work the switch and you can see if the mechanism is working to pump the pump. Works like a cam and so forth.............B
Old Oct 25, 2006 | 12:07 PM
Durango_Boy
Sorry, mine may be different. It was also a general tip used for a lot of different kinds of bottles from a lot of different cars.
Old Oct 25, 2006 | 04:15 PM
markdtn's Avatar
markdtn
Switch works to ground the pump. Check to see if you have 12v on 1 lead at the washer pump with the car running. Then with the wipers running, if you ground the other lead at the pump you should hear it trying to work. If it doesn't, you may need a new washer pump as well. Take it off and do bench diagnostics. If originality is not a concern, just buy a universal pump and plumb it in.
Old Oct 26, 2006 | 10:21 AM
Durango_Boy
Any luck? A DMM and you should know in five minutes.
Old Oct 26, 2006 | 12:51 PM
karioth's Avatar
karioth
dont have the car with me just yet, stupid shop didnt order a part when they were supposed to so its still 400 miles away. The washer pump is brand new FYI.
Old Oct 26, 2006 | 12:53 PM
Durango_Boy
Obviously a wire or switch problem.
Test at the pump first with the switch being operated from inside.
Then, if that fails, test at the switch to see that it's working. If not, replace it, and test again.
Hope you get your car soon.
Old Nov 14, 2006 | 12:06 PM
karioth's Avatar
karioth
a lot of cursing and troubleshooting later, found out the brand new pump was bad
Old Nov 14, 2006 | 03:15 PM
Durango_Boy
Did you throw any tools...toss a washer pump at the garage wall?
Old Nov 14, 2006 | 03:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Made a 30-foot basket with a washer pump about 10 years ago...
In this case, the lines or nozzles might be plugged. Washer fluid sometimes leaves behind deposits that clog things up.
Old Nov 14, 2006 | 07:08 PM
Durango_Boy
Yep... ...especially if you use that RainX washer fluid crap. That stuff gummed up two of my cars...and it's a pain in the butt to get in there to clean it all out.
Old Nov 14, 2006 | 07:47 PM
whoodiestyle's Avatar
whoodiestyle
this is most likely a stupid question but where is the washer button at i have never had to use it but my wipers i was trying to figure it out the other day??
Old Nov 15, 2006 | 11:33 AM
Durango_Boy
The stalk that controls the wipers, rotates forward I think. Either that or the entire stalk pushes inward toward the column. I can't remember exactly since I never used mine either. I'm gonna remove my washer bottle anyay.
To Windshield washer pumps wont fire
