yes they do, and can be a fire hazard.
you may also be running to rich, its fuel in there burning. A hi flow replacement isn't very expensive and will give you a little perf bump. Also get the carb jetting checked out.
Is this thing factory original? If so, it's way past time for a replacement. The ol' pancake style cats sucked to begin with and several decades don't help. I think you'll be pleasantly surprised at the jump in power with a modern hi-flow replacement such as Catco, magnaflow etc.
Why would my cat converter be glowing red ? do they get clogged up ?
It is burning off unburned fuel remaining in the exhaust stream, just as it was designed to. It won't continue for long, though, because it was never intended to deal with that volume of fuel except for very briefly. You have problems upstream that need to be dealt with asap. Don't run the car except for diagnostic purposes until the problem is solved.
Yes, I have been having trouble with it flooding when it starts . should I replace the Catalytic converter first ? Would that solve my choke problem ?
No, though you may have ruined the cat by overheating it...so it may need to be replaced.
I disagree with this statement if it is still the factory pancake converter. Those should definetely be replaced as they were extremely restrictive when new and for sure plugged up by now.
And yes, fix the choke. Is the choke pull-off working? It's supposed to open the choke about 1/2 once the engine starts. It's a little vacuum can. If it is broken the engine will flood/run really rich cold.
The symptoms he's given do not indicate a plugged cat, whatever the vintage so, strictly speaking, replacing it won't address his problem(s).
That said, yeah, you really couldn't be more right about the original cats sucking. Heh, I once heard their restrictive nature described as "like trying to exhale through a marshmellow". Fortunately, cats have come a helluva long way since then! They are not restrictive enough now to be of any consequence that I know of, at least on a street car. If it is the original piece, no way would I leave it in place.
I sort of doubt he has the original tucked under there as it is functioning (glowing red indicates that it is operational), the original piece would still be working way beyond its expected lifetime, but I guess is is possible in a low mileage car.
I'm sure it's the original cat.conv. It's coming off next weekend. It was a scarry sight to see under the car. I thought for sure I was going to have a fire. The bad part about it was that I couldn't start it again because of my choke problems . It won't start after its been running.
