Tire Pressure Needed!
Old Oct 27, 2006 | 04:10 PM
yankees1's Avatar
yankees1
Default Tire Pressure Needed!
I have Goodyear Eagles GT II on my 72 vette. Size is P225 70R15. I don't think this is the stock tire size for this vette and not mentioned in the manual. What tire air pressure should I use? I e-mailed Goodyear but they responded back that I need to ask the car manufacturer. Advice?
Old Oct 27, 2006 | 05:03 PM
MakoVette's Avatar
MakoVette
aybe this will help http://www.tirerack.com/tires/Spec.j...irePageLocQty=
Old Oct 27, 2006 | 05:04 PM
chris73cpe's Avatar
chris73cpe
the owners manual for my 73 says 15psi, but 32 is a pretty safe number to use today. You can always adjust up and down depending on how they wear
Old Oct 27, 2006 | 05:43 PM
yankees1's Avatar
yankees1
Originally Posted by MakoVette
Tire Rack shows max as 44 psi. But what is normal psi to inflate to? 30 psi? Thanks!
Old Oct 27, 2006 | 06:08 PM
crazywelder's Avatar
crazywelder
You have the metric equivalent of the original G70-15. I run my 225's at 30 psi.
Old Oct 27, 2006 | 06:21 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I run my 255s between 30-32 psi.
Old Oct 27, 2006 | 09:34 PM
Sayfoo's Avatar
Sayfoo
I have the same tires in 255/60/15 on my 69 bb and I run 28 or 30 lbs. Depends on which of my 2 gauges I use. Your gauge would probably read differently than mine also. Anyway, the tires are about 2/3 gone and they are wearing even all across the tread.
To Tire Pressure Needed!
