Muncie date code clarification
Old Oct 29, 2006 | 10:32 PM
alaskacorvette's Avatar
alaskacorvette
Default Muncie date code clarification
I'm trying to make sense out of muncie date coding. For example:P1T15A on the stamp. One of my books says the first 1 is for the model year of the car. The other book says the first 1 is for the date assembled. If the first scenario is true, would the transmission have been built on Dec.15, 1970? If the second scenario is true then the transmission would have been built Dec.15, 1971? Thanks for the help!
Old Oct 29, 2006 | 11:09 PM
MidShark's Avatar
MidShark
My old '71, which was built in the fall of 1970, had the"1" for the model year. The trans was assembled in August of 1970.
Rich
Old Oct 29, 2006 | 11:56 PM
myoriginal77's Avatar
myoriginal77
Old Oct 30, 2006 | 09:20 AM
stingr69's Avatar
stingr69
The production trannys were stamped with the "year model", not intentionaly the assembly year.
But that does leave the question open as to how they stamped "CT" service replacement trannys for over the counter sale. They could theoreticaly fit several year models as a service part so they might have been stamped differently. I leave that out on the table for a separate thread if someone else wants to stir the pot.
-Mark.
Old Oct 30, 2006 | 11:09 AM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
P = Muncie 4speed
1 = model year (not calendar year)
T = December
15 = 15th
A = M20 wide range
(Transmission built Dec 15, 1970 for 1971 car ... serial number/VIN would indicate a factory part - lack of serial number/VIN would indicate a service part)
Reference: NCRS Manual(1968-69) and
Corvette by the Numbers, 1955-82, A. Colvin
What books are you referencing in your query?
Old Oct 30, 2006 | 10:56 PM
alaskacorvette
Default references
Frank, I have "Chevrolet by the numbers", it is correct. The book "corvette 1968-1982 Restoration Guide, Richard Prince" is confusing.(1999) On page 118, top right column, second full paragraph:" the date the transmission was originally assembled". The next paragraph refers to the "number representing the last digit of the model year". Prince's book is generally pretty good. Thanks for the help.
Old Nov 2, 2006 | 12:19 PM
5speeds's Avatar
5speeds
I wrote a whole thing on I'ding Muncies here.
http://www.5speeds.com/muncie2.htm
Old Nov 2, 2006 | 12:52 PM
alaskacorvette
Default Thanks
I'll check your site out. Thanks for the help. Jim.
To Muncie date code clarification
