Seat Back Help
Old Nov 5, 2006 | 09:54 PM
DO2G's Avatar
DO2G
Default Seat Back Help
The button on the back of my drivers seat doesn't work. How can I get the seat back forward (to clean behind) and how does the system work?
Old Nov 5, 2006 | 10:01 PM
Tom73's Avatar
Tom73
Does the passanger side work? If so fold it forward and check out the locking system.
Old Nov 6, 2006 | 05:58 AM
Bob Onit's Avatar
Bob Onit
When you say "doesnt work" are you saying it depresses but nothing happens or is it not possible to push in?...very stiff
My pass side button was stuck and I was not able to push the button in.
I took off the chrome trim that surrounds the button, sprayed oil around the button and let it work it's way down and while rocking the seat back and forth it finally popped in.
It's been fine ever since
Make sure the shoulder belt retractor isnt holding the seat from moving forward as well
Old Nov 6, 2006 | 07:23 AM
DO2G's Avatar
DO2G
It doesn't move. I have now taken off the trim piece and tried to push the botton and now it broke off. The shaft is still attached to the seat back. I wedged a screwdriver in there and rocked it back and forth, but no movement. I guess i will try to figure it out form looking at the passenger side.
Old Nov 6, 2006 | 08:07 AM
Bob Onit's Avatar
Bob Onit
I just took a look at my AIM and if the '78 is similar to my '73 there should be 2 screws down low on the seat back cover and then you should be able to lift up on the seat back cover to remove it and it and then you should be able to see all the linkage
To Seat Back Help
