Bumper cover swap?
Old Nov 7, 2006 | 02:38 PM
BFI's Avatar
BFI
Default Bumper cover swap?
Can the 80 to 82 bumper covers be swapped to the earlier sharks that had the plastic bumper covers? I would really like to have a convertable with the later front and rear bumper covers. What is involved in this swap if possible. Thanks for any info.
Old Nov 7, 2006 | 02:47 PM
NHvette's Avatar
NHvette
Yes, they either fit direct (rear) or they have conversion covers (front).
This idea will only work with 74 or 75 ... if you want to do it to a vert.
On the other hand, a late C3 can be made a vert ... with a "little" more work.
Old Nov 7, 2006 | 03:09 PM
SteveG75's Avatar
SteveG75
Rear bumper. Easy swap for a 74 or 75.
Front bumper, lots of fiberglass and snd support to be changed.
Old Nov 7, 2006 | 05:09 PM
crazywelder's Avatar
crazywelder
The rear '80-'82 covers will fit '74-'79 (see my pictures). As mentioned the stock '80-'82 front cover would require some major body mods. But there is a look-a-like '80-'82 style front bumper that will fit '75-'79 with no mods to the body. It's close but not exactly the same, ACI part number EBF020. Here's a link.......http://www.acivette.com/
Old Nov 9, 2006 | 04:23 AM
78CO_VETTE's Avatar
78CO_VETTE
Not to hijack this thread but I was also wanting to put an 80-82 bumper cover on my 78. My questions are:
1) Where is the best place to buy from?
2) which material is best to get (fiberglass, urethane, or trueflex)?
Seems to me that the trueflex would be the best being semi flexible and easiest to match the color of paint being no need for a flex agent in the paint but at Corvette America there trueflex bumper part #143122 says it will fit 78-79 with modification. I understand that probably any bumper would have to be fitted but is there any other/better options out there?
Old Nov 9, 2006 | 06:38 AM
crazywelder
1) I prefer American Custom Industries (ACI) for quality and mold accuracy. The other large manufacturer is Toledo-Pro. You can buy from ACI direct.
2) I prefer regular fiberglass because if filler is required to match the body shape, I feel standard fiberglass is a better foundation than flex fiberglass.
The rear bumper is usually an easy fit but almost every bumper will need filler for the best fit, so count on using some filler. Urethane bumpers flex to the body shape, fiberglass doesn't. I'm not sure why Corvette America has that note about modification for '78-'79 but the '80 style bumper will fit '74-'79. I do know that the Toledo-Pro bumper is 1" shorter at the bottom. Mods will be required to the reinforcement and tail light mounting brackets on '75-'79.
To Bumper cover swap?
