steering column options
Old Nov 11, 2006 | 07:47 PM
68 NJConv 454's Avatar
68 NJConv 454
wow Jim, very impressive. You must have great memories being a part of the creation/design of such an amazing car. I bet back in the day you had no idea you were a part of something so special that in the years to follow people would be so involved in enjoying/tinkering with these vettes.
So a 77 sounds like a much better fit and I'm sure its easier to come by.
Is it correct to assume that the "A" & "B" brackets that I noted above in my pics from a 77 would also be a direct bolt-in to my 68 so I could install a 77 tilt/tele column?
I would rewire to have the highbeam dimmer & wiper on the column.
I want to keep the ignition on the dash, is it possible to cut & patch the column to remove the ignition and keep it on the dash?
BB, how much of a pain is the 96 column install? you keeping the 96 steering wheel? I would imagine the airbags would be a huge PIA to make work with all the sensors and such. What column functions are you planning on making functional?
Old Nov 11, 2006 | 09:20 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
The 96 column install is not easy. I am doing a Jeep box with an intermediate, energy absorbing shaft/coupling. This requires the column to be shortened. I have no plans to make the airbag functional. That is something that would require crash testing
Old Nov 11, 2006 | 10:32 PM
68 NJConv 454
Lets go find some junkyard lincolns or taxis and destruction derby here we come. (u can test ur airbag system and I'll give my right foot/calf some physical therapy) As dangerous as it appears I have a blast watching these derbies from the stands, I bet its a blast in the hoopdie car!
You converting the wiper and highbeam dimmer switches to the column? I would like to do this when I get a hold of a 77 column. I want to leave the ignition in the dash though.
Take pics of what you have to go thru with ur 96 column. I must have 500 pics of everything I've done with my frame-off on my 68. Before and after pics are awsome!
Old Nov 12, 2006 | 04:38 PM
Jim Shea's Avatar
Jim Shea
I have a lot of information on C3 steering columns. I have zero information on C4s and C5s.
I do not know how easy or difficult it will be to install the 1977 type column support bracket into your 1968.
Take a look at my paper on installing a 1977-82 column into a 1969-76 Vette. The dimmer wiring information at least will be of help.
http://jimshea.corvettefaq.com/wp-co...3Rev06JN06.doc
Yes, I would think that you should be able to eliminate the ignition lock cylinder bulge on the side of your column. You should be able to saw it off and patch it with epoxy or bondo. You should probably back it up with screening. Be sure to take the lock bolt out of the column. Since you will have most of the guts out of the column anyway, you sure don't want it somehow migrating back and locking up the column while you are driving.
The 1977 (and later) columns also have the small lever next to the lock cylinder (called the finger inhibitor) which can be eliminated as well.
If I were to guess, I think your major fit problem will be where the column head meets the instrument cluster.
Jim
Old Nov 12, 2006 | 09:37 PM
68 NJConv 454
Originally Posted by Jim Shea
If I were to guess, I think your major fit problem will be where the column head meets the instrument cluster.Jim
Thats what I was thinking too, guess we'll just have to see as I go along with the instrument cluster. I didn't even think about the locking aspect of the column. Thanks for pointing that out.
Just trying to find a column and brackets now. Trying some vette salvage yards since restored columns are running big bux these days. More than a chrome aftermarket column with todays technology and features. Weird.
Thanks Jim and BB for your help and info. I'll take lots of pics and try to do a write up.
