steering column options
Old Nov 9, 2006 | 10:22 PM
68 NJConv 454's Avatar
68 NJConv 454
Default steering column options
1.) what year steering columns will work in my 68? i have the original but want tilt/tele. I'll end up with an aftermarket wheel anyway.
2.) what other options are there? will a c4, c5, c6 work? i would get rid of all electronics but blinkers. It would be neat to reroute my wipers to the column.
Would like to limit mounting modifications to a minimum.
ideas?
Old Nov 10, 2006 | 01:12 AM
68RATVT's Avatar
68RATVT
Two words, Flaming River.....
Old Nov 10, 2006 | 02:44 AM
68 NJConv 454
...three numbers & a symbol, $529
gotta be an alternative out there, flaming river has nice columns but mucho dinero
what i'm finding out is that a 69 vette column won't fit a 68. Only columns from 66 thru 68 are interchangable, this true?
Old Nov 10, 2006 | 02:52 AM
DZRick's Avatar
DZRick
Only columns from 66 thru 68 are interchangable, this true? I'll be interested in the answer to this too.
http://www.columnsgalore.com/
http://www.corvettesteering.com/
I got these Only columns from 66 thru 68 are interchangable, this true?2 after doing a search, both had very good reveiws by those that used them.
Old Nov 10, 2006 | 07:19 AM
Jim Shea's Avatar
Jim Shea
Only the 1967 and 1968 Corvette steering columns will interchange. The only production, collapsible, energy absorbing, steering columns available are the telescoping column and the standard (non-adjustable) columns.
The 1967-68 Corvette columns were special in that they had smaller diameter tubes than any other GM columns. So the later Corvette and GM T&T and tilt columns will not fit through the instrument panel.
I personally don't recommend other brands of steering columns because they were not designed to collapse and absorb energy (particularly in cars that are driven on public roadways.)
Jim
Old Nov 10, 2006 | 10:18 AM
68RATVT's Avatar
68RATVT
Jim, no offense meant, Flaming River builds nothing but quality parts. Certainly a collapsible column is a safety feature, how be it small. We are talking about a fiberglass car with little safety, the column may be the only thing. And I have to ask, how collapsible is it when it's tele'd out and locked?
Old Nov 10, 2006 | 11:11 AM
68 NJConv 454
I agree, safety should always be taken into consideration...did they make t&t columns in 67 & 68? i thought i remembered reading somewhere that the standard NON-tilt/telescoping columns were standard/stock on the 68's. I hope I'm wrong. I hope tilt/telesc was an option taken advantage of from buyers so I can find one lying around somewhere.
Flaming river also has the new columns out that are lazer cut and made specifically to colapse 2 inches under significant pressure from a colission...but that ups the anti to $599 but that gives you a general column, i'm sure its more to get a colapsable 68 vette version with tilt/telesc.
So my best bet is search for a 67 - 68 tilt/tel column right?
Anyone want to part with one? doesn't have to be complete and pretty, i'll clean it up and transfer the needed parts off my standard column. Fleebay only ever has 73 and up.
Old Nov 10, 2006 | 01:38 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
If you change the column mounting bracket to a 69-up bracket (the big steel casting and steel plate) and make an adapter plate for the firewall mount, you can use a later C3 column in a 68. I'm not sure there was a tilt/tele in 68, think it was tele only. They are not cheap and difficult to find parts for.
Old Nov 10, 2006 | 09:24 PM
markdtn's Avatar
markdtn
It is not the actual column itself that collapses much, it is mostly the shaft between it and the steering box. Columns killing people in wrecks was a real issue until the collapsible columns became required. I am converting a '66 Rustang project I have to a '67 collapsible column. I would not drive a car that didn't have one.
Old Nov 10, 2006 | 10:06 PM
68RATVT's Avatar
68RATVT
Agree, it is a great safety feature, but if you get in a collision bad enough to need it in a Vette, chances are thats going to be the least of your worries, right?
Mustangs are great cars, sturdy and steel. Understandably collapsible could make a big difference.
Old Nov 10, 2006 | 11:36 PM
BBShark's Avatar
BBShark
I think that if you were involved in a frontal impact in a C3, the steering column going through your chest would be your greatest worry. Whatever can be done to put crush between you and the frame is good regardless of what kind of car you are driving and, next to seat belts, the most effective safety equipment in a C3.
I does concern me that people sometimes disable this feature by collapsing the steering shaft when doing steering conversions. I hope they realize the risk they are taking.
Old Nov 11, 2006 | 12:58 AM
68RATVT's Avatar
68RATVT
HHHmmm, True enough...
Old Nov 11, 2006 | 02:22 AM
68 NJConv 454
Hummmmm...I am installing a jeep box and was told I need to colapse my column to make way for the jeep box, i think it has to be shorter 1 inch. WTF!
Anyone have pics of a 69 or later bracket that i would need to fab up an adapter for? trying to visualize in my head.
My column is fastened to the car with a bracket/plate(A) that sits below the column that sandwiches it to a large heavy cast bracket(B)that is fastened to a metal bracket(C) that is fastened to the body/firewall. See pics below... so I need to fab a bracket from (C) to a new (B) from a 69 or later? has anyone done this yet? any pics? any pics of a 69 or later brackets?
Old Nov 11, 2006 | 11:28 AM
Jim Shea's Avatar
Jim Shea
Vehicle Crash Dynamics 101
There is about 7 to 8 inches of collapse designed into the Saginaw
C2/C3 energy absorbing steering column. In a severe frontal crash the design collapse distance is used up in two ways. First, the vehicle front end crush (i.e. the frame and steering gear moving rearward toward the body) and second, the driver impacting the steering wheel and driving the upper end of the steering column into the instrument panel.
The lower steering shaft (sticking out into the engine compartment) has about 3.6 inches between the end of the strg column and the top of the detachable column flange. So in a very severe frontal collision the gear and frame could be driven back and up a couple inches causing the steering shaft to collapse from the engine side (this would take up 3.6 inches of the 7 or 8 built into the column or about half.) After the 3.6 inches is used up, the lower car floor and the steering column jacket now have to start to deform and move into the passenger compartment.
A few milliseconds later, the driver (without a shoulder belt) would slam into the steering wheel causing the upper end of the steering column to be driven into the instrument panel. (This is where the energy absorbing feature of the Saginaw column comes into play.) The upper end of the steering column moves into the instrument cluster and absorbs driver energy as it moves forward. The clearance designed into the instrument panel where the column passes through allows for that collapse distance. This could take up the remaining 3 or 4 inches of collapse.
Now when you shove the steering shaft back into the column to make room for the Jeep gear or the Steeroids R&P, you do reduce the available 7 or 8 inches by an inch or so. This would only make a difference in a very severe frontal collision.
With a rigid steering column any crash movement of the steering gear rearward causes the steering column shaft to move rearward by the same amount. This causes the steering shaft and steering hub with the wheel to begin to move rearward out of the strg column. Now the driver's body moving forward hits the steering wheel/strg shaft moving rearward. Not a pleasant thought.
Jim
Old Nov 11, 2006 | 12:30 PM
68 NJConv 454
Originally Posted by Jim Shea
Not a pleasant thought.Jim
No, not at all. Thanks for the info. Great design.
Jim, if you had a 68 with a non-tilt column and really wanted to convert to a tilt/telescoping column what would you do?
and no, buying a car with one is not an option
1.)Convert the mounting brackets to a later C3 colapsable tilt/tele column? or 2.)go with an aftermarket colapsable such as flaming river?($600)
I'm leaning towards fabing up some mounting brackets for a later C3 column b/c I feel more comfortable that these were specifically designed for the C3 engineering but I also don't want to diminish the actual design engineering geometry by changing the original mounting design. By changing the mounting it may affect the overal safety and how the column would react in an unfortunate event.
Why did they change the column designs in 69? are they safer than a 67/68?
Old Nov 11, 2006 | 01:41 PM
BBShark's Avatar
BBShark
The brackets "A" and "B" in your pictures could be replaced with 69-up brackets. It is a bolt in swap, no modifications. The firewall bracket could be replaced also. This bracket is available from junkyards.
If you are doing the Jeep box conversion, you will find that you have to push the steering shaft in 2.5 inches minimum. This is if the pitman arm is to remain in the same place is the Vette arm. The Jeep gear will need to be rotated so that its input shaft is aligned with the column. The Jeep box is taller than the Vette so the input shaft is higher (unless rotated down). You will need to to use a U-joint coupler to make up for this misalignment and the couplers are longer than the rag joint. I think all in all you will have to push the shaft in at least 3 inches if not more.
A little tip for the Jeep box conversion. Use a mid 70's A body power steering pitman arm. 5 1/5 inches center to center, bolt in, no welding!
Old Nov 11, 2006 | 02:37 PM
68 NJConv 454
The brackets "A" and "B" in your pictures could be replaced with 69-up brackets. It is a bolt in swap, no modifications. The firewall bracket could be replaced also. This bracket is available from junkyards. A little tip for the Jeep box conversion. Use a mid 70's A body power steering pitman arm. 5 1/5 inches center to center, bolt in, no welding!
Thanks BB,
I got the jeep box quick ratio unit from corvettesteering so its a direct bolt in. Resplined and all to accept the stock pitman arm. Kit also came with
So I can get the "A" and "B" brackets from a 69+ donor car and they should be a direct bolt-in? then I would just have to get a 69 or up tilt/tel column? any years I should stay away from or aim for? i.e. would a 73 or 78 work?
I wish I could get a column mounted highbeam switch instaed of the foot switch.
Thanks guys for the info.
To steering column options
Old Nov 11, 2006 | 02:55 PM
Jim Shea's Avatar
Jim Shea
Energy Absorbing Steering Columns 102
The first generation energy absorbing (EA) GM steering columns (all 1967-1968 passenger cars) had an expanded mesh section in the jacket tube. The mesh convolutions were designed to bend on themselves and absorb energy as the column collapsed. Unfortunately, this type of steering column was pretty whimpy in bending. This is why you will note that most 1967-68 columns had big mounting brackets with three and four aluminum breakaway capsules to hold the column into the instrument panel. This capsule bracket "band-aid" basically kept the column from bouncing in your hands as you drove down the road.
Saginaw new that in 1969 the ignition lock cylinder was going to be added to the steering column, which added mass and complexity to the steering column head. This would make a whimpy column even worse!
So Saginaw designed a second generation energy absorbing steering column with what is called the "ball EA" design.
With this design, the upper jacket (driver end) telescoped over the lower jacket. As the jackets moved, the ball bearings (which filled the gap between the two jackets) plowed grooves in the two parts and absorbed energy. This 2nd design was far stiffer than the mesh jacket used the first two years. (All 1969 and later steering columns only required simple two breakaway capsule mounting brackets.)
Jim
Old Nov 11, 2006 | 03:03 PM
BBShark's Avatar
BBShark
Originally Posted by 68 NJConv 454
Thanks BB,
Yes the 69-up brackets are bolt in, no mods. I have them in my 68. The later columns are supposed to be shorter and a more comfortable driving position. I don't have any experience with this as I am putting a 96 Vette column in mine. I believe Jim Shea wrote a paper on adapting a late C3 column to an early (69-77?). You will have a different "harmonica" connector on your 68 harness and will have to figure how to wire the ignition switch.
Old Nov 11, 2006 | 03:40 PM
Jim Shea's Avatar
Jim Shea
I wasn't involved with the design of the EA columns for the C2/C3 Vettes so I can't provide accurate history. However, I can provide the obvious differences.
For some reason, Corvette (and the Corvair) were the only 1967-68vehicles with small diameter jackets. (I don't know why - possibly it might have had something to do with the cutout in the carryover instrument panels to provide room for the column to collapse.) Both of these cars had standard (non-adjustable) and optional telescoping (only) steering columns. There were no tilting columns with small diameter jackets (I don't know why.) I do know that you can't just take tilting or T&T column parts and try to add them to an existing Corvette/Corvair column.
I just don't know about trying to adapt a 1969 through 1982 T&T column into a 1967-68 Vette.
I can provide the following comparison of the 1969-1976 T&T column to the 1967-68 standard column:
Overall length tip to tip of strg column shaft 67-68 36.77 inches
Overall length 1969-76 T&T (telescope shaft retracted) 38.7 in
Length from strg shaft tip (strg wheel end) to capsules 67-68 15.7 in
Length from strg shaft tip (telescope shaft retracted) to capsules 69-76 16.8 in
Length from strg shaft tip (engine end) to capsules 67-68 21.1 inches
Length from strg shaft tip (engine end) to capsules 69-76 21.9 inches
Length across column (capsule to capsule) 67-68 3.49 inches
Length across column (capsule to capsule) 69-76 4.74 inches
I would imagine that you would try and keep the threaded studs that hold the capsule brackets in the same location (they will have to be wider apart (4.74 - 3.49 = 1.25 inches). This will also mean that the steering wheel will be 16.8 - 15.7 = 1.1 inches closer to the driver (even with the T&T shaft retracted).
The engine end of the steering shaft should not be a problem. Also, the lower column brackets are spot welded in place on both steering columns. You might have to exchange brackets.
Let's try a 1977 T&T column compared to the std 1967-68.
Overall length 1977 T&T (telescope shaft retracted) 37.0 in
Length from strg shaft tip (telescope shaft retracted) to capsules 1977 15.4 in
Length from strg shaft tip (engine end) to capsules 1977 21.6 inches
Length across column (capsule to capsule) 1977 4.74 inches
The 1977 T&T column will bring the steering wheel back to within 0.5 inch of the original column.
Don't forget, these columns have the lock cylinder on the column head and the ignition switch is mounted on the column. The 1977 column has the dimmer switch on the column. (It also has the windshield wash/wipe switch built into the column as well.)
Jim
