Wheel spacer question
Old Nov 14, 2006 | 07:43 PM
MassaRusty's Avatar
MassaRusty
Default Wheel spacer question
I just got some 18x9.5 wheels with 5.5 inch backspacing. When I mounted them, the clearance on the inside seemed a little close. I probably have about 1/4 inch of clearance after I cut off the parking brake bracket. I was planning on using a 1/4 inch spacer and I don't know if I need to get longer studs or not. How many threads of engagement is good when I put the lugnuts. If I need longer studs, what length do I need? Thanks.
Old Nov 14, 2006 | 08:45 PM
jpatrick636's Avatar
jpatrick636
If you do not have at least one thread past the nut, you need longer studs. I have seen people run with a couple of threads left on the nut, but for safety I would not do it. Studs are cheap, why risk it?
Old Nov 14, 2006 | 10:15 PM
Gordonm's Avatar
Gordonm
I am running 18X10 in the rears with a 5.5 backspace and have no problems at all rubbing. Running 275 40 18s in the rear. It is tight but no rubbing. The sidewall does not flex much with the 40 series tires.
Old Nov 15, 2006 | 10:38 AM
lowbuck72's Avatar
lowbuck72
TIA says the absolute minimun is to engage enough of the stud equal to the thickness of the stud, ie. a 7/16" stud should engage at least 7/16 " of threads. However they also discourage the use of spacers.
Old Nov 15, 2006 | 01:11 PM
PRNDL's Avatar
PRNDL
Is there any rubbing? I don't think "close" matters at all as long as there is no contact, and you can hear/feel if there is contact. Are you sure you need a spacer at all?
Old Nov 15, 2006 | 03:45 PM
1tuffref's Avatar
1tuffref
If you can get by without using the washer type spacers do it. They are bad news because they put the entire load of the car on the lugs instead sharing it with the wheel hub. The "safe" alternative is the bolt on spacer that bolts to your existing lugs and has another set of lugs to bolt the wheel to. To answer your question though, standard engineering practise is to have at least one full thread protruding through the fasterner. This ensures the sheer strength of the threads exceeds the tensile strength of the lug.
Old Nov 15, 2006 | 06:40 PM
MassaRusty's Avatar
MassaRusty
I have read most of your threads about your wheels and that is why I felt comfortable getting the 5.5 inch backspace. I think I will go ahead and buy the spacer to have it on hand if I need it, but I will drive it for a while and see if I have any problems. I have the same tires as Gordonm, but on 9.5 wheels instead of 10 inch like he has. He is sure pushing more power than I am on my c3.
I don't want to use an adapter because if I need to move the wheel out, it will only be about 1/4 inch. I haven't seen any adapters that small.
To Wheel spacer question
