long gone are the days of harsh chemicals, wirebrushing and smelly solvents.....
last couple of weeks ive been using a home made electrolysis cleaner and life has gotten SOOO much easier.
For those who have no idea what im talking about imagine this.
plastic tub of water. Add cup of Arm and Hammer "WASHING SODA" this is important that its Washing Soda (2.29 at Publix grocery) for every 5 gallons of water
get some rebar or a metal stake and clamp to side of tub (i used a 20 gallon tub)
get a small battery charger (im using a 50 amp) bigger, faster it works
connect the positive lead to the rebar/stake, connect the negative side to the part.
drop in waster and make sure rebar/stake and part do not touch. Turn on charger
Go back hour or so later (time depends on your part and how dirty it is), pull out part and most all of the paint and grease, and RUST, and grime has "fallen" off.
All the part needs now is a washing down with a SOS soap pad and it will look like new metal.
Ive done the whole front suspension and each piece looks like new with no solvents.....
Best part is i can pour the old water in the flower beds....
It works BETTER then you can imagine. Im still amazed
Disclaimer.....I havent found anything unsafe with this so far, but do at your own risk.
Comments?
This proves that electrons actually move from Negative to Positive and that the Negative side of a battery is actually the "hot" side. The Electrons move from the Part to the rebar and take the crud with them.
I can't wait to try this. I'd think however that you should degrease parts first. Seems like a coating of grease would interfere with the current.
I've had pretty good luck soaking rusty cast iron parts in vinegar for 24 hours or so. The vinegar (acetic acid) etches the iron to get rid of rust, but does it so slowly that it doesn't damage the cast iron part.
I'll have to do a google to find out what washing soda is. Sodium Biphosphate maybe? Sodium bicarbonate is the stuff you put in bread dough.
Disclaimer.....I havent found anything unsafe with this so far, but do at your own risk?
Since electrolysis splits water into it's elements (hydrogen and oxygen) sparks from the clamp connections could ignite the gasses if they concentrate and the room is not well ventilated!
Experiment before you try to clean that one of a kind part, especially alloys. Aluminum will disintegrate if left in the electrolyte too long. Plated parts can also be damaged.
Wonder how it would work useing a metal drum instead of the rebar thing?
Or what about multiple rebar shafts, clamped around the tub like markings on a clock? Then run a single hot wire, connecting them all, and the neg on the part. Wouldn't that create more paths and help erode the grime faster?
It would certainly help to clean all sides at the same rate.
However, I think "faster" would be limited by the current output from the source (battery charger).
Re: metal drum .... the steel is sacrificial and "melts" away.
Use a steel drum and return to a room full of washing soda solution.
I wonder...if you had a big enough tub, enough water and soda...could we dip our own bare engine blocks and heads too? Will it clean inside the water jacket and oil galleys? That'd be cool.
