DC current will clean the piece and erode the sacrificial steel (polarity correct).
Reversing this will have reverse effect ... clean steel and erode the piece.
AC line current will clean both and erode both (60 times per second).
I don't think you want the second effect. Stick with DC.
If you heat the water to about 60 degrees it is much more effective.... We use it for old engines parts and rubber gaskets..... and I use it for my Vette parts
OK -DC only-the reason I ask was I have a 1600 volt AC low amp elecrtic fence charger.Thought maybe I could put it to good use.
i can tell you this....i put my tie-rod assemblies in the tub. hour later went back and got them out. rust and grim gone. loosened the end bolts and twisted all 4 tie rods out by hand. every part ive tried in there comes out great. even the belly pan for the 72, it removed rust/dirt/and 90% of the paint. IM SOLD
Yup, AC changes polarity. A rectifier can be used to change the AC to DC, it consists of a step down transformer, and a diode bridge.
Faraday's law is what determines the weight loss. The weight of material is directly proportional to the current. 1 amp of current discharging off steel will remove 20 lbs of steel in 1 year. 2 amps will remove 40 lbs, etc...
The anode undergoes an Oxidation reaction, losing Fe++, the electrons that go through the metallic path (wire) to the cathode (part to be cleaned). The cathode is negatively charged, and wants to grab some OH+ molecules and add electrons to them, removing the oxide from the iron; rust (FeOH)
The electrolyte (baking soda water) is an ionized solution capable of conduction electricity. Anions move from the cathode to anode, NaHCO3 (baking soda) has Na+ ions and HCO3- anions.
