removing seatbelts
Old Nov 19, 2006 | 04:26 PM
britvette's Avatar
britvette
Default removing seatbelts
Ok so I started telling the wife that I was going out to the garage to mess about with the vette for 1/2 an hour this morning and 3 1/2 hours later I had the interior of the car out (one thing led to another - you know how it goes!!)
Anyway I want to take the carpet out to give it a good clean but I can't get the !@#$%^ seatbelts off!! They are held on with a star? type bolt that I assume needs a special tool to remove?
A 1/4" allen key fits it pretty well but I cant shift them and dont want to screw the head of the bolt up.
So what do I need to get this bolt off , whats it called (I assume its a kind of socket?) ,and where can I get it?
Thanks for your help
Old Nov 19, 2006 | 04:38 PM
vettecrazy88's Avatar
vettecrazy88
Torx driver T40, 45 or 50 most likely. Most hardware or auto stores have em.
Old Nov 19, 2006 | 04:40 PM
mark79,80's Avatar
mark79,80
Torq drive, it is a T50 size. They are available at most
auto parts stores and tool stores.
Old Nov 19, 2006 | 05:01 PM
britvette's Avatar
britvette
Thanks a lot for the info - much appreciated
Old Nov 19, 2006 | 05:09 PM
onaqwst's Avatar
onaqwst
soak the threads with pb blaster/rust eater first... from the top and underneath........
this is one of the harder bolts to take off........ (besides the t-arm bolt)
b
Old Nov 19, 2006 | 07:30 PM
britvette's Avatar
britvette
thanks for the heads up
Will do
Old Nov 20, 2006 | 03:20 PM
Scottys78's Avatar
Scottys78
I had to use an impact gun to brake them loose… they can be really stubborn
Old Nov 20, 2006 | 10:10 PM
britvette's Avatar
britvette
Picked up a t50 torx driver today - All 4 bolts came out no problem - Amazing what you can do with the right tools
What the hell were they thinking putting those bolts in in the first place - whats the point?
Am I supposed to put them back in with a torque wrench? - if so what torque? Think I will put a little anti sieze paste on them when they go back in if they are supposed to be problem bolts.
Thanks to those that offered advice - carpets now out and cleaned
Drying in garage as I type
Old Nov 20, 2006 | 10:36 PM
chevy69's Avatar
chevy69
St. Jude Donor '08
Glad to hear they came right out - mine were a real bear
To removing seatbelts
