1973 Engine ID help needed
Old Nov 26, 2006 | 07:35 PM
gleninsandiego's Avatar
gleninsandiego
Default 1973 Engine ID help needed
I was looking at a 1973 Corvette for sale today. According to the VIN number and the center console, the car came with the L82, 350ci 250hp engine. The owner, who has had the car since 1984, claims it is the original engine. The owner had the engine rebuilt right after they first got it, but claims it is the original block ect. The receipts seem to verify this. However, and this is big however, the vin number is not on the metal pad by the water pump where I am used to seeing the vin number stamped. On the rear of the engine block there is a couple of numbers cast on the block. One number is 3970010. The other number was smaller and looked like 2273. On the sticker with the vin number, it said the car was assembled in 4/73. So my question is, do you think this is the original engine or was the block replaced sometime between 1973 and 1984?
Glenn in San Diego
Old Nov 26, 2006 | 08:10 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Default NO #'s ??
Originally Posted by gwgwgw
I was looking at a 1973 Corvette for sale today. According to the VIN number and the center console, the car came with the L88, 350ci 250hp engine. The owner, who has had the car since 1984, claims it is the original engine. The owner had the engine rebuilt right after they first got it, but claims it is the original block ect. The receipts seem to verify this. However, and this is big however, the vin number is not on the metal pad by the water pump where I am used to seeing the vin number stamped. On the rear of the engine block there is a couple of numbers cast on the block. One number is 3970010. The other number was smaller and looked like 2273. On the sticker with the vin number, it said the car was assembled in 4/73. So my question is, do you think this is the original engine or was the block replaced sometime between 1973 and 1984?
Glenn in San Diego
NO #'s on the pad ???? i'd be a scared !!!
buy it & pay as if it was a NO MATCH car, most likely the heads were decked & the numbers removed at that time, but you can now never ever prove if it was a matching motor or not, & will always have a story attatched when it comes time for resale etc.........as well as never brining the same money as a car with the correct numbers on the pad. what is the vin on the car ? curious ? & where is this # located exactly ? photo avail ? how about numbers on manifold, bell housing - tranny, rear ????
ZIXXX PACKER
Old Nov 26, 2006 | 08:15 PM
wfo76's Avatar
wfo76
The VIN needs to be on the pad. Since he had the engine rebuilt the shop probably decked the block and destroyed the pad, very dumb thing to do but they do it all the time. Are the other engine stamp numbers on the pad? The 2273 first character should be a letter for the month but the date sounds right. It probably is the original block, but the wiped stamp definitely hurts the value so the price should be reduced accordingly. I would just act like it is an NOM car when haggling with the seller. Good luck.
oh, it's an L82 btw.
Old Nov 27, 2006 | 12:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Unless I miss my guess, your pad numbers were machined away at the time the previous owner had the engine rebuilt. Ask and see whether he/she remembers the block being decked at that time. Block number and casting date are otherwise correct for an April, '73 car.
Old Nov 27, 2006 | 01:27 PM
Tom73's Avatar
Tom73
This is one reason that the numbers matching thing can get a bit wierd.
You can have a matching number engine that is the original engine;
You can have an original engine that does not have numbers;
You can have matching numbers but the engine is not original;
or You can have a non-matching numbers and the engine is not original.
So, Which is best, Matching Numbers or Original Engine??
Old Nov 27, 2006 | 10:22 PM
427SIXPACK's Avatar
427SIXPACK
it does get a bit weird but i dissagree with the part of your thread that says, " You can have matching numbers but the engine is not original;" thats the main function in my opinion that the numbers in the vin match the numbers on the motor, thats the most important & most value driven part of the whole concept. ZIXXX PACKER
ANYONE ELSE ?
Old Nov 27, 2006 | 10:43 PM
Tom73's Avatar
Tom73
ANYONE ELSE ?
A restamped block can be matching numbers but still not be the original engine that came in the car from the factory.
Old Nov 27, 2006 | 11:04 PM
427SIXPACK's Avatar
427SIXPACK
I ASSOCIATE A RESTAMP AS FRAUD NOTHING LESS !!!
Old Nov 28, 2006 | 02:04 AM
gleninsandiego
Thanks for the input. Anything obvious about that engine? What makes it different?
The intake manifold had this number cast in it 899771
Glenn
To 1973 Engine ID help needed
