t-top question
Old Nov 28, 2006 | 10:38 AM
Flighthog's Avatar
Flighthog
Default t-top question
Hello to all New vette owner but not new to old chevy's. I recently bought a 74 vette but with a 1980 body on it. I think the tops are from the 74,back part of the top has a v in it for the r=triangle bolt also has a place for the latch lever. The body has a plate with a spring loaded switch. Not sure what parts to get to make it latch. Thanks
Old Nov 28, 2006 | 11:43 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
69-77 triangle halo panel latches will work. Before you remove the 78-80 hardware be advised there is a tapping plate in the halo panel behind the latches which hold the theft alarm switches for the tops. You can expect these to fall to the bottom of the pillar unless you remove the interior trim and get a hand on them.
You second option is to purchase a pair of 78-82 tops.
Old Nov 29, 2006 | 01:10 PM
Flighthog's Avatar
Flighthog
Hey thanks for the help. One other question is there also supposed to be a latch to hold it down or does the triangl bolt hold it ok.
Old Nov 30, 2006 | 12:17 PM
Easy Mike's Avatar
Easy Mike
Triangle at the rear outer corners; latches at the windshield header; tongues and receivers on the T-bar.
To t-top question
