Ignition Wiring Problem
Old Nov 29, 2006 | 12:08 AM
bene's Avatar
bene
Default Ignition Wiring Problem
I just bought a 71 Vette that had a deactivated aftermarket alarm. After carefully removing all the wires, the car will not start. You don't even hear a click. Started fine before. I need to know where the wiring goes. The alarm had a wire that was hooked to the igniton fuse box. I did not cut any wires when the alarm was taken out. Any help would be appreciated.
Old Nov 29, 2006 | 06:10 AM
sdonnelly's Avatar
sdonnelly
A lot of alarms split the wire to the starter. So if you removed the wires from each side of that wire (probably a good size red) and did not put the two original ends back together, you get nothing. Nada, zip. Trace the red wire from the starter until you find a break. That should, hopefully be it.
Old Nov 29, 2006 | 07:14 AM
markdtn's Avatar
markdtn
Originally Posted by sdonnelly
A lot of alarms split the wire to the starter. So if you removed the wires from each side of that wire (probably a good size red) and did not put the two original ends back together, you get nothing. Nada, zip....
The actual wire to engage the starter is purple.
Old Nov 29, 2006 | 01:01 PM
bene's Avatar
bene
Thank you. I found the purple wire from the starter that had been cut. It starts right up now. Thanks again
To Ignition Wiring Problem
