quick wheel polish question
Old Nov 29, 2006 | 12:50 AM
whoodiestyle's Avatar
whoodiestyle
Default quick wheel polish question
ok i went out and bought some mothers polish and a power ball i cleaned up one wheel by hand only spent about 10 mins on it to test it out but my question is how exactly do you guys use the powerball do u apply the polish by hand on there and use the ball on it and whipe it off with a clean rag?? or what methods do you guys use?
Old Nov 29, 2006 | 01:04 AM
comp's Avatar
comp
i haven't used one yet myself
Old Nov 29, 2006 | 08:53 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I have both, the small and big powerball. The smaller ball works a lot better on the rims than the big ball. I'm not too happy with the metal polish that came with my powerball, mother's chrome polish works a lot better.
I apply the polish by hand (paper towel).
Old Nov 29, 2006 | 07:08 PM
whoodiestyle
so you apply it with a paper towel and the just use the ball on it and then wipe clean right?
Old Nov 29, 2006 | 08:34 PM
bluegtp's Avatar
bluegtp
I use some stuff called way too easy.....or way2easy.....kinda got a grit to it......and works awesome.....I've compared half and half with this and the mothers.....went and bot my brother and he said the way2easy was shinier.....not knowing which was which.....
I have a cloth ball, but same basic thing though.....I usually just spread some on there with the ball and then get after it......here's some before and after pics!
Old Nov 29, 2006 | 09:44 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
exactly
You'll have that polish everywhere (including the ceiling if you do this in your garage) if you try to apply it with the ball.
Old Nov 30, 2006 | 08:28 PM
whoodiestyle
so the im guessing the bottom one is the way2easy stuff? looks shiny
Old Nov 30, 2006 | 10:48 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I have 4 Vettes, All with alum wheels, Just spent all of last weekend doing wheels on Wife's 84. apply with fingers or rag and start to rub in. then hit it with the ball hard, if it go's dry apply more, again at least get it started by hand, then hit it with the ball, dont be afraid of a little force. then finish by hand and keep useing fresh rags to clean away all the black stuff. our black 77 is next, I CAN wait.
Old Dec 1, 2006 | 12:46 AM
bluegtp's Avatar
bluegtp
cool, thanks! the bottom two pics is with the way2easy...the top two are right when I bought the car after it set up for 3 years.....
I stand by that stuff cause it does a great job on older stuff that needs a good polish and works great on keeping things polished.....if you check out my cardomain on my grand prix.....the wheels look great!.....
mothers is great stuff too......polishing is some work!..specially going from dull to shine......takes a lot of time, but once they're shiney it doesn't take much to keep them up atleast!
ryan
Old Dec 1, 2006 | 01:01 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I used the same stuff called "Way2Easy" and it worked fantastic!!!
Old Dec 1, 2006 | 12:22 PM
whoodiestyle
ok well 3 wheels went good so far but the 4th wheel feels like it has so sort of rough finish to it and it wont poilish i got a lil bit to shine but the rest wont?
Old Dec 1, 2006 | 09:04 PM
bluegtp's Avatar
bluegtp
if it's pretty bad you may need to get some steel wool or like a 1500 or 2000 grit sand paper.....worse comes to worse you can start with an 800-1000 grit and work your way to a 2000....
do the sand paper and then work you polish on the wheel....
later!
ryan
Old Dec 2, 2006 | 12:46 AM
whoodiestyle
thanks for the help it worked i used some steel wool on it and it looks nice now
Old Dec 2, 2006 | 01:40 AM
bluegtp's Avatar
bluegtp
great!....glad i could help you out and you didn't have to sand on it.......keep it clean!
ryan
Old Dec 2, 2006 | 01:48 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The return of the famous Comp
To quick wheel polish question
