Side Exhaust Insulation Install Advice
Old Dec 10, 2006 | 01:42 PM
kaiserbud's Avatar
kaiserbud
Default Side Exhaust Insulation Install Advice
Has anyone installed the Side Exhaust Insulation from Paragon?
Obviously the foil side goes to the pipes, but hoping to get more particulars on this. One side has the foild all teh way to the edge, I assume that goes to the outer edges of the covers? Is there anything to hold it in place or does it actually get wedged under the body fiberglass as the body sets down?.
Old Dec 11, 2006 | 10:25 AM
exhaustkid's Avatar
exhaustkid
from my exp. the heat shield can be glued on either way. but the best way is the way you described. the alum side tward the side pipe. if you need any more info shout back.
Old Dec 11, 2006 | 11:35 AM
kaiserbud's Avatar
kaiserbud
I actually wasn't planning on using glue - is that something you have heard is appropriate? If I have enough room, I may alternate the material to a mnore heat resistent technology ... now that I have seen the part I ordered.
Old Dec 14, 2006 | 11:23 PM
kaiserbud's Avatar
kaiserbud
ttt
To Side Exhaust Insulation Install Advice
