Door Panels
Old Dec 10, 2006 | 08:47 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Default Door Panels
I've been looking at new door panels. You can buy them 3 ways: Bare, Standard, or Deluxe. Is it a pain to transfer the hardware if you get the bare ones? Or is it worth the $$ to go ahead and get the deluxe with everything new and in place??
Thanks!!
Old Dec 10, 2006 | 10:24 PM
7T1vette's Avatar
7T1vette
If your hardware is in good shape [chrome good, trim not marked up or dented], then I recommend you transfer yours to a new "basic" door panel. If you are reasonably careful in removing your trim, it shouldn't be a problem. You can cut off the overlapped tops of the rivets on the armrest chrome piece; then you can drill and tap the remainder of the rivet and screw it together with small screws...or you can do as I did--epoxy the remainder of the rivets in place with JBWeld.
P.S. Look at the locations of the pin holes from the armrest "U" trim on your old panels and try to duplicate the same pattern when you put the trim in the new panel...it will help you get good alignment in the groove.
Old Dec 10, 2006 | 10:30 PM
...Roger...'s Avatar
...Roger...
I would go for the deluxe.It takes alot of time to do a nice job changing over and one slip can mess it up.
Old Dec 10, 2006 | 10:38 PM
vettecrazy88's Avatar
vettecrazy88
Took me 4-5 hours of not hurrying time and some "while I'm at it" touch up painting. From other threads, I'm about 1/3 slower than someone that knows what they are doing, or has done it before.
Note bottom chrome trim exact location for transfer. Angle and alignment can shift a little if transferring carpet wedge over.
It was worth getting basic and transferring hardware for me.
Old Dec 11, 2006 | 10:22 AM
dkw's Avatar
dkw
I agree with the above replies that you can buy the basic panels and transfer the hardware. I did my 77 this summer however, if i had to do it again I would buy the deluxe panels. For the extra $$ I think you would get a better job, less frustration, and save a lot of time and also have all new harware.
Old Dec 11, 2006 | 10:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Considering the addtional cost isn't all that much, go with the deluxe.
Old Dec 11, 2006 | 11:14 AM
rcread's Avatar
rcread
I did this a while back and transferred my old hardware to the new bare panel. The dealer who sold the panels recommended this method because, according to him, the hardware that comes installed with the panel is imported junk. I thought transferring all of the stuff was very easy and I am quite happy with the results.
Old Dec 11, 2006 | 05:48 PM
...Roger...
Hmmm imported hardware-that would be worth considering.
DP77 I didnt mean to imply this was a really hard job-mainly time consuming but if the hardware is junk then you might want to consider doing it yourself.You just have to be careful and the use of a hair dryer makes it easier.I use a dremel to make any holes.I would caution you about using a blade.
Old Dec 11, 2006 | 07:43 PM
Scottys78's Avatar
Scottys78
I did it the hard way and got the bare...
Worked out good though
Old Dec 12, 2006 | 12:15 AM
7T1vette's Avatar
7T1vette
Be careful about using the hair dryer. While it will smooth out some wrinkles on the flat areas and the "outside" curved surfaces, it can do a lot of damage in the "inside" crevices like the armrest surface. Heat makes this material shrink...and shrinking an inside curve is bad news. Use the heat gun sparingly.
To Door Panels
