Well i want to put a dvd flip up scren head unit into my car(like the one here Jensen In-Dash CD/DVD/MP3 Receiver w/ 7" LCD Touch Screen
Now how can i install that and make it look like it fits, i dont see alot of bezels, that fit in my 78, sincei guess i have to buy one with all the gauges and all..
So how can i make thi work...
if this really is an issue, you can buy a repro bezel that is already formed to accept a DIN radio housing. keep in mind, however that depending upon the screen size, you will be blocking some if not all of your gauges (not recommended to say the least). most states require that the unit be wired in such a way that it cannot be operated while the car is in motion if mounted in the front seating area. you might want to be careful regarding that. it will produce a pretty stiff fine (moving violation and points in most places).
