Car audio upgrade ?
somehow that seems to be the way most of my projects turn out....
That bezel is a bastard to cut though. Use masking tape on any area not to be cut incase you slip with the dremel.
That's clean. Good job.
Thanks,
Joe
Here is the finished product:
Thanks DB!
You can see it and all my car-audio installs on my homepage
I finally broke down and cut the bezel and installed a Pioneer unit, best thing I ever did. Sounds great, works great and its been in for 3 years without a hitch. I cut the bezel and fabricated a front facia and it looks great.
He explained that perfectly. Those tabs he mentioned are what hold everything in place. Make sure those tabs are bent out so that everything is tight, and nothing wiggles. If it wiggles at all, the head unit will move around as you drive, and may cause wires to come loose or even skipping CDs.Something I recommend, is a block of soft foam behind the stereo, on top of the trans tunnel. When the head unit is pushed in for it's final resting position, it compresses the foam, and rests it weight on the foam instead of dead air. Also, the pressure that foam applies as it pushes up on the bottom of the head unit, helps keep everything tight and secure.
One more tip. Make all your wires, including the antenna wire, long enough to pull through the bezel, and attach to the head unit. You'll want to test it before inserting it for good. Make sure it plays and has a radio signal.
To help with splicing into the harness, these are the important wires from the back of the head unit.
Red - IGN lead. Important so the stereo is only active when the key is in the IGN position.
Yellow - Always hot 12V source. This keeps the memory of the head unit.
Black - Ground. Just as important as the power wire.
Antenna - Also a ground, and this is your radio signal.
Blue/White stripe - Remote wire for turning on amps.
Blue - Remote wire for turning on power antennas.
If you have a multi meter, check all the wires before installing. Find and mark which wires from the car's harness is the 12V, IGN, and GRD.
Let me know if you have any other install questions.
.. No thanks .. I will get another standard bezel and get a top end din unit for a lot less.
