Question on changing Master cylinder?
Dec 28, 2006 | 12:44 AM
My father was changing the master cylinder, when he removed it the rod from the booster fell out. Should that be able to slide out? He pushed it back in and installed the master cylinder and now when you push on the pedal it makes a click noise that it didn't previously. Any advise would be appreicated.
Chuck
Dec 28, 2006 | 01:17 PM
Chuck,
when you say the rod 'fell out' do you mean fell out of the booster?
No they should be attached to the booster.
I don't remember how they are attached, but that might be your click. I'd definitly verify it's solidly connected.
Keith
Dec 28, 2006 | 01:40 PM
keith,
Yes, it fell out of the booster. I thought it was strange that it was not retained some how.
Chuck
Dec 28, 2006 | 01:57 PM
Dec 28, 2006 | 03:03 PM
On my 78' it wasn't attached and comes right out. just insert it back into the booster (the correct way) and you'll be good to go.
Dec 28, 2006 | 04:10 PM
The rod in my old vacuum booster in my '77 slid right out too. It wasn't sheared or broken.
Dec 28, 2006 | 05:59 PM
Thanks for the replys guys.
Chuck
Dec 29, 2006 | 12:42 PM
I'm curious to find out how many, if any, of the rods were not attached but simply held in place by the master being bolted to the booster.
Dec 29, 2006 | 02:32 PM
Quote:
Originally Posted by
Durango_boy
That's how mine was when I replaced the MC on my 73 last weekend.
Dec 30, 2006 | 01:23 PM
c3andc5
I guess some were fixed and others were loose. Go figure.
