PS Performance
Old Dec 28, 2006 | 09:07 PM
pdege's Avatar
pdege
Default PS Performance
I'm new to Corvettes and I'm having trouble getting use to the 'icy' feeling in the power steering of my 1980. My newer and older cars have more resistance in the wheel which feels comfortable to me.
Is there any way to get a better feel in the steering wheel other than doing a rack and pinion conversion?
Old Dec 28, 2006 | 09:29 PM
Durango_Boy's Avatar
Durango_Boy
You're saying the steering is too easy for your tastes? Hmm...not sure I hear that very often.
I'm not even sure how you fix that. Changing to manual steering may be the best option, you just have to find the parts from a used donor manual steering Vette.
Old Dec 28, 2006 | 10:48 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
put some big *** fat tires on the front. That'll fix it. Also sometimes when front tires are over-inflated it may steer too easy.
Old Dec 28, 2006 | 11:09 PM
Durango_Boy
You could also fill them with a mixture of water and anti-freeze and give yourself great traction on grass and uneven turf.
Old Dec 29, 2006 | 06:51 PM
pdege's Avatar
pdege
ttt
Old Dec 29, 2006 | 07:27 PM
JPhil's Avatar
JPhil
I know what you mean. I think you'll pretty much just have to learn to get used to it. Unless it's beyond what I noticed with my car, which I wouldn't know unless I drove your car, it's just the way they feel (or more correctly, don't feel). Yeah check tires, pressures, alignment front and rear, etc., but I don't feel much from my steering either.
Welcome to the weird world of old Vettes.
John
Old Dec 30, 2006 | 08:55 AM
72 LT1's Avatar
72 LT1
I've got the same problem w/ my 72. PS feels over boosted/has very little road feel/feed back. I've driven BOTH PS and manual steering C3's.The manual steering cars have a pretty decent road feel, MUCH better than PS. I have never driven a C3 w/rack and pinion swap. Swapping to manual steering is the LEAST expensive way to get better road feel, IMO. I'm looking into what has to be changed, and will post AFTER I have made swap.
Old Dec 30, 2006 | 09:23 AM
jnb5101's Avatar
jnb5101
i think there is an adjustment on the control valve that decreases pump pressure. that will increase effort needed to turn wheels. there was a thread about this some time ago.
Old Dec 30, 2006 | 09:26 AM
pdege's Avatar
pdege
The XKE P/S pumps had a compression spring in them which I assume control by-pass pressure. I simply replaced the original with a weaker spring and voila! I'd be real interested in what you come up with.
Old Dec 30, 2006 | 09:50 AM
Ganey's Avatar
Ganey
You are on the right track.
Steering, feel, etc. is excellent on mine. Have driven some w/ too light PS.
I read a long time ago about someone making a hotrod Seville (70s RWD) & he changed the PS "spool" to one from a Trans Am.
Markus (zwede) added a shim internal to PS on his 71 to increase st. feel.
Old Dec 30, 2006 | 10:12 AM
MN80Vette's Avatar
MN80Vette
You can change your alignment to have a little toe-in (1/32" vs. 0" or out?).
SpeedDirect also sells a kit to reduce the pressure for GM Saginaw pumps. It is a series of spacers added into the pressure valve of the pump. The kit costs $16 plus shipping. You can call them: 888-425-2776
BTW, changing to manual R&P system will give you a lot more road feel, but a power R&P steering system isn't going to get rid of the icy feeling. That's why SpeedDirect sells the pressure reduction kit - because comments about lack of road feel from Steeroids owners is common, including me.
Old Dec 30, 2006 | 01:19 PM
72 LT1's Avatar
72 LT1
I havn't heard of press. reduction kit. For $16, I'll give that a try first! Thanks for the tip!
Old Dec 30, 2006 | 01:41 PM
Durango_Boy
That spacer kit may work wonders for his application. Good suggestion.
Old Dec 30, 2006 | 09:12 PM
pdege's Avatar
pdege
A call to the 'spacer man' will be made Tues!!!
Old Jan 3, 2007 | 06:30 PM
Durango_Boy
So? What's the word on the kit? I'm curious too.
Old Jan 3, 2007 | 08:37 PM
StickShiftCorvette's Avatar
StickShiftCorvette
If you reduce the pump pressure I believe you will have more "lost motion" in the steering valve, making the steering feel worse.
I have thought about putting stiffer springs in the valve or shimming the centering springs in the valve - done correctly this could provide you with manual steering at speeds above 20 mph and power below that speed (with a little more effort than stock PS).
I just added PS to my '69 after 145,000 miles and 30 years of FAST manual steering and have some concern about the steering feel - but with my sticky 17" tires have just gotten tired of fighting the steering at low speeds.
Old Jan 3, 2007 | 08:39 PM
StickShiftCorvette
The C2/C3 power steering doesn't use a spool in its valve. On my '68 Impala I bought a blueprinted Trans Am box with a high effort torsion bar (spools do not effect steering feel or effort) and it is FANTASTIC.
To PS Performance
Old Jan 3, 2007 | 08:40 PM
Durango_Boy
I'll bet your arms got good and big though huh?
Old Jan 3, 2007 | 09:10 PM
Restorod '79's Avatar
Restorod '79
I converted to manual steering for "road feel". All my hydraulics were leaking too. I had to get a manual relay rod/ center link, replaced the tie-rods with VBP adj., got a heavy-duty idler arm, and had to get the outer holes machined in the spindle arms. Everything is tight and the feedback is incredible. TOO incredible. I'm fabricating a Rancho shock to replace the hydraulic arm and act as a stabilizer. If I hit a curb I could break my wrist! The steering is hard at low speed, so I avoid low speed, and good drivers don't turn the wheel until the car is moving anyway.
From the searches I've done, and pics I've seen, rack and pinions sit too low for my application. I would like manual R&P. The nicest feeling wheel I've ever used was in a '95 Civic with manual R&P.
Old Jan 4, 2007 | 11:26 AM
pdege's Avatar
pdege
I ordered the kit from Speed Direct today. The info that I got from the phone person was sketchy. Price up to $20+$8.50. Will report back when it arrives.
