XFIRE Backfire
Old Jan 5, 2007 | 08:15 PM
reelthing's Avatar
reelthing
Default XFIRE Backfire
My 82 is acting up; when I go to romp on it, it sputters and backfires.. It has 80K original miles and I never have taken apart the TBIs. What should I be doing to fix the problem?
Old Jan 5, 2007 | 08:22 PM
1-MORTOY's Avatar
1-MORTOY
I had a similar problem with mine & solved it (temporarly) with a can of injector cleaner. I eventually ended up replaced both inj's & it is running better than it ever did.
Oh, You might also want to check the ignition bits too, cap cables etc.
Old Jan 5, 2007 | 10:33 PM
britvette's Avatar
britvette
You may already be aware of it but the crossfire vault forum has a lot of very experienced guys with lots of knowhow on the ins and outs of the crossfire injection
heres a link just in case
http://www.crossfire.homeip.net
Old Jan 5, 2007 | 10:56 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Cars are no different then people, thats what happens after you eat baked beans
hope you cure your troubles !!!
To XFIRE Backfire
