vette trailer
Old Jan 9, 2007 | 11:20 PM
panic's Avatar
panic
Default vette trailer
what trailer specifications are the best for transporting a C3, i mean length, 2 or 4 wheels, etc...anybody has some trailer pics? thanks/Giu
Old Jan 10, 2007 | 06:26 AM
guppie's Avatar
guppie
St. Jude Donor '08
Here's mine, I think it's 18'
Old Jan 10, 2007 | 06:29 AM
panic's Avatar
panic
thanks guppie it's a nice trailer and shows perfectly what i'd need.
Old Jan 10, 2007 | 10:50 AM
68RATVT's Avatar
68RATVT
Panic, Don't have a picture yet,still being built,another week or so.
It's a 16ft x 81" wide, double axle with front axle electric brakes. I couldn't buy one "off the shelf" because I need it with 4" drop axles and they lower the fenders down. It has 8 d-rings spaced through the floor and rings on the front/back/sides,also a cross bar in front. Floor is 2x6 treated bolt down and finally painted grey. Some guys are buying tilt beds for lower cars,but it adds 1000 pounds. The Vette should drive on without blocking,same with my hot rods.Looks alot like a Carson trailer,but Called a Tru-trailer.
Old Jan 10, 2007 | 11:01 PM
SwedeAWACS's Avatar
SwedeAWACS
If it's a one time move, I used a U-Haul auto hauler, open trailer. Tandem axles, surge breaks when I PCS'd from Alabama to Colorado, pulled behind my Ford Expedition
Old Jan 11, 2007 | 12:13 AM
Frenchican's Avatar
Frenchican
I have an 18' Challenger, C3 fits no problem.
[IMG][/IMG]
Old Jan 11, 2007 | 12:52 AM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Here's mine. Enclosed 16' x 8'-6", tandem axle, torsion type soft ride suspension. Full drop down rear door with extension apron for drive-in loading.
I've hauled my C3, and C5 in it, and both load without difficulty. The wheel wells are inside the trailor, so it does limit your ability to open the doors very wide. I will fix that one of these days by installing 2" x 12" runners for the wheels to rest on when loaded. For now I just crawl out through the top.
Old Jan 11, 2007 | 09:34 AM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Like stated above, opening the doors is the tricky part. If you get a trailer low enough so the car doesn't scrape when you drive up the ramps, the fenders block the doors. Some tandem tailers have removeable or fold down fenders. Other folks raise the height of the car with boards - some only on the driver's side. Another technique is to get in / out of the car as soon as the back wheels are up on the trailer - so the door can swing open more fully. The car can then be winched / rolled forward in neutral to the transport position and secured.
When I transported mine home, I used the technique of removing the roof, standing up, and stepping in/out. I could open the door enough to insert /remove the key, install the roof panel, and hit the power window switch. It made me long for the days when I had a C5 with the window valet so I could open / close the power windows from the keyfob.
Old Jan 11, 2007 | 10:50 AM
Glensgages's Avatar
Glensgages
1991 Econo-Trailer:
I had tool-box/storage-box added a few years later, for chains, ratcheting-straps, trailer-ball, a small- ack, etc.
Old Jan 11, 2007 | 11:08 AM
7DStingray's Avatar
7DStingray
32'
Old Jan 11, 2007 | 11:55 AM
Scottys78's Avatar
Scottys78
24'
Old Jan 11, 2007 | 01:35 PM
panic's Avatar
panic
thanks all of you for showing your trailers and giving me all the infos, what i definitely need is an open trailer, i guess a 18' will be enough, i want to take my vette back home to italy every summer and as i usually drive with all the family in june to italy and take everybody back to spain in late august, then i could take also my vette with me, if i had a trailer...i'll check here what's ready to be bought and that could legally be driven (i know there must be a lot of BS to comply with anyway)...
Old Jan 11, 2007 | 01:49 PM
Scottys78's Avatar
Scottys78
I don’t know about in Europe but in the u.s. there isn’t that much to have a trailer…just registered (for the tag) and have it inspected. Don’t even need insurance because when it’s hooked up to the truck it’s on the trucks insurance
Old Jan 11, 2007 | 03:36 PM
panic's Avatar
panic
basically it's the same (i know italy but i think spain is about the same as well)...registration/inspections but i think you need a special (lorry type) driving licence to drive it IF car+trailer is longer then a certain length which i will have to check, also speed must be reduced like on trucks, i guess is 50 mlh!! so if i wanted to have a 2.000 mile trip on the motorway (like going back home on summer) it would take me maybe a week to arrive (even if i'd tow it in full security with a porsche cayenne...and not a small economy car)...
Old Jan 11, 2007 | 03:52 PM
Scottys78's Avatar
Scottys78
Whatever you do… good luck with it
And be careful
Old Jan 11, 2007 | 03:58 PM
Restorod '79's Avatar
Restorod '79
Some features I looked for are:
Two axles @ 3500 lbs.- common
Electric brakes on all four wheels-
15" wheels with a good load range tire.
beaver tail ( sloping rear deck) for low vehicles to clear.
16' works for me- lighter the better!
LONG ramps for loading- I ordered custom aluminum- +@300 bucks
Maco Shark's Avatar
Maco Shark
Here is a pic of my trailer, it has a removable wench and a c3 does just fine.
I have pulled a c3 over750 miles one way and no problems yet.
To vette trailer
Old Jan 11, 2007 | 04:22 PM
Glensgages's Avatar
Glensgages
..... most-overlooked, but much-needed accesory is a SPARE TIRE & WHEEL!!!!!
ALL my friends made-fun of me for 'paying an extra $100 for a spare' .....
..... until 15 of us are towing 200 miles to the races, and one of them suffers a flat:
..... THEN, I suddenly became their best-friend!
Old Jan 11, 2007 | 05:01 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
How much do your trailers weigh without the car? with the car?
Old Jan 11, 2007 | 05:10 PM
Glensgages's Avatar
Glensgages
I believe my trailer empty tips-the-Toledos at around 1100 pounds, and while the Z28 and '82 C3 probably go 3500 themselves, I've also had a 4WD Blazer on my trailer, with no adverse effects:
you gonna do much racing in '07, ruby?
