540 Dyno Run Part II
Old Jan 10, 2007 | 05:34 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default 540 Dyno Run Part II
I just got off the phone with TNBUSA. They finally got his motor on the dyno today and called him with the results. I had told him earlier to call me when he found out what the motor made.
Mike can add all the details but the hard numbers are
719 HP and 687 Ft Lbs on 93 pump gas. The pull was stopped at 6000 RPM and HP was still climbing.
Sounds like Mike put together a pretty darn good combination of parts!!!
Old Jan 10, 2007 | 06:37 PM
TNBUSA's Avatar
TNBUSA
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07
Thanks for the post Ed, but it was only 718hp and 680 something ft lbs. We were busy when he called so I didnt catch eveything he was telling me but he did seem a little surprised with the results. Im going to pick it up tomarrow and will get a copy of the dyno sheet and some more info. Im happy with the #"s considering the fairly mild combo (weanie hyd roller cam) So Ed, whatcha doin this weekend
Old Jan 10, 2007 | 06:42 PM
Eddie 70's Avatar
Eddie 70
This weekend I think I may have something to do...................maybe help install a new hot rod motor.
Old Jan 10, 2007 | 08:39 PM
SILVERSIXX's Avatar
SILVERSIXX
Sweet numbers boys!
Old Jan 11, 2007 | 06:53 AM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Sweet.
Pics please.
Old Jan 11, 2007 | 10:24 PM
Eddie 70's Avatar
Eddie 70
Originally Posted by 74 vert
Sweet.
Pics please.
I will see if I can squeeze a few photos in while the install is going on. Stay tuned.
Old Jan 12, 2007 | 11:28 AM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Very impressive! What is this going in??
Old Jan 12, 2007 | 10:51 PM
Jamie Slick's Avatar
Jamie Slick
From: "The people you choose to surround yourself with define who you are..."
Cruise-In VIII Veteran
it's going in my hubby's 70 coupe. Here are a few pics I took this evening:
if anyone wants to help with the install this weekend, come on over!
Old Jan 13, 2007 | 10:44 AM
74 vert's Avatar
74 vert
Oh, I want to, but I'm in my last class and need to work on that. Hay, get a can of Whip AZZ and place it on the intake when the engine is planted in the bay, 'cause that is one no non-sense piece of machinery. I bet that Yellow C6 is just nervous as hell.
Old Jan 13, 2007 | 12:50 PM
toddalin's Avatar
toddalin
Is that a Keisler shift ball? I didn't get one of those with my TKO600.
Old Jan 13, 2007 | 07:34 PM
pef427's Avatar
pef427
Now that's just plain sexy!!! Post some video when that monster is running. I love those valve covers. I have got to get busy or I will be walking to BG this year. The burnout contest will be monumental this year!
-Patrick
Old Jan 13, 2007 | 08:02 PM
Eddie 70's Avatar
Eddie 70
Well, I was a little late today and they had the motor already installed when I got there. It looks great in there. And that is one HUGE carb on that bad boy. We went to a car show later in the day and there was a camaro race car there with a 750-850??, anyway, it looked puny compared to the one pictured. This is going to be fun.
Edit: I took my camera but took no pictures. Janie took some while I was there. She just has to post them in here. I will send the PM.
Old Jan 13, 2007 | 10:26 PM
TNBUSA's Avatar
TNBUSA
Cruise-In VIII
Toddalin, it came with the factory looking shifter but I live close to Keisler and I asked them if I could trade for the Hurst handle with the white ball and they said sure!
Old Jan 14, 2007 | 12:30 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Now I need to go get my covers polished or chromed!!
Looks good!!!
JIM
Old Jan 14, 2007 | 07:00 AM
TNBUSA's Avatar
TNBUSA
Cruise-In VIII
Thanks Jim, Going to try to get the side pipes on today. Im not looking forward to this...the AFR's have a raised exhaust port so I dont know what all problems I will run in too.
Old Jan 14, 2007 | 08:51 AM
Jamie Slick
Here's a link to the thread I started in OT with lots of pics of the entire project:
http://forums.corvetteforum.com/show....php?t=1597398
Old Jan 14, 2007 | 09:26 AM
Eddie 70's Avatar
Eddie 70
Tell Mike to give me a holler if he would like some help today. I am more than willing to give him a hand.
To 540 Dyno Run Part II
Old Jan 14, 2007 | 10:12 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
You darkside guys are scaring me. I'm going to have to add a blower and nitrous just keep up. Jim is a bad influence on you guys....
Great Job...
Old Jan 14, 2007 | 10:23 AM
Eddie 70's Avatar
Eddie 70
Great Job...
Ha!!! You LS guys are a bad influence on me. My car runs fine and will go anywhere anytime. Still, it NEEDS an LS motor.
Old Jan 14, 2007 | 10:41 AM
pef427's Avatar
pef427
Hey Mike,
Losing my sidepipes and Hooker headers was not an option. I was determined to make them work. But I really dreaded this part because so many said it wouldn't be possible or they would look bad from all the hacking and welding. IT WAS EASY! Cut the flange off and buy a new set. Bolt them to the heads and then feed each tube (bends easy without the flange) into a port and tach weld. I held the collector in postion with the sidepipe to make sure they were straight. Go slow!
The steering box took a little grinding but even though the head is raised it actually rolls the header out and down. I trimmed a little at the body but the rocker panel covers that.
Good luck,
Patrick
