Emergency brake light ?
Old Jan 11, 2007 | 02:30 PM
pchmotoho's Avatar
pchmotoho
Default Emergency brake light ?
Last night I drove my 71 for the first time in a couple months. While stopped and pressing the brake pedal the e brake light came on. I got home and checked the fluid (it was good).
Any ideas on where to go from here. Thanks in advance.
Old Jan 11, 2007 | 02:34 PM
Cocky B's Avatar
Cocky B
Happened to me. You need to bleed the brakes. You might have a bad proportioning (sp?) valve.
Old Jan 11, 2007 | 05:00 PM
GTR1999's Avatar
GTR1999
Light come on if you pull the PB handle or if there is a pressure shift between the front and rear chambers( leak) Look for a leak at the calipers, lines, hoses, and rear of the M/C.
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Fluid/pressure issue. Fill, bleed, etc. To reset the light start the car and push it down as hard as you can for at least three seconds. You will feel a kind of blip in the pedal and the light will reset.
Old Jan 11, 2007 | 09:15 PM
pchmotoho's Avatar
pchmotoho
Thanks for the info.
To Emergency brake light ?
