Finally!
Old Jan 22, 2007 | 06:19 PM
jotto's Avatar
jotto
Originally Posted by GD70
Thanks!
A few questions,
I discovered today that the secondaries are not opening under full throttle, why I believe the power's not what I was expecting? Why might that happen?
On a Qjet, the secondaries are vacuum operated and will only work with the engine running and under load. You will not see the secondaries open at full throttle if the car is not moving.....
Make sure the secondaries are free to move when the engine is warm, they will be locked out when cold. If they move freely, chances are they will operate correctly when the car is moving.
You say the carb was a refurb....where was it purchased? there have been alot of posts recently about how so called carb rebuilders just pull parts from various years carbs to make a supposedly working one...yours may not be like this but it may be worth checking.
Good luck, welcome to the forum and enjoy the car!
Old Jan 27, 2007 | 02:01 PM
Durango_Boy's Avatar
Durango_Boy
I've heard that JCW rebuilt carbs never work right.
