Finally!
Old Jan 19, 2007 | 08:24 PM
GD70's Avatar
GD70
Default Finally!
Hi All!
Just bought my 30 year dream 1970 coupe. Donnybrook green,black standard int. Originally 350-350 L46, not original motor now, 4 speed. O/A good condition. Motor was rebuilt py 2 owners back, power's not what I was expecting though. The block is 75, intake 69, Q-Jet 71. Came with an extra Aluminum manifold GM 14057053 CFM 44 (for 80-88) & Holly 6210-1 carb. Would intake-carb swap give better power? Many more questions to come.
Thanks in advance!
Old Jan 19, 2007 | 09:16 PM
Durango_Boy's Avatar
Durango_Boy
Is there a budget at work here and how far are you looking to go to achieve your goals. Also, do you even know what you want to do? Obviously, more power is the goal, but how far would you like to go?
Old Jan 19, 2007 | 09:18 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Originally Posted by GD70
Hi All!
Thanks in advance!
CONGRATS
Post some Pics
& register here >>>>>>>>>>> http://www.c3registry.org
Old Jan 20, 2007 | 07:10 AM
guppie's Avatar
guppie
St. Jude Donor '08
Congrats on purchasing your dream car and Welcome to the Forum.
Old Jan 20, 2007 | 11:25 AM
Durango_Boy
Silly question, but have you already learned the 'Wave?'
Old Jan 20, 2007 | 11:34 AM
vette70's Avatar
vette70
Default Congrats
Great news that's a grest year. Send us some pix when you can.
Good Luck
Vette70
http://mywebpage.netscape.com/portfo.../RONSPAGE.html
Old Jan 20, 2007 | 01:02 PM
FKING1's Avatar
FKING1
Bought a 70 L46 Muncie 4 spd 1-1/2 yrs ago and love it. Plenty of power for Autocrossing.
Fred
Old Jan 20, 2007 | 02:52 PM
vette70's Avatar
vette70
Default Congrats
thumbs:
Good Luck
Vette70
http://members.***.net/shley2002/Corvette/index.html:
Old Jan 20, 2007 | 02:54 PM
vette70's Avatar
vette70
Default sorry double post
was doing something and hit wrong button
Old Jan 20, 2007 | 03:28 PM
GD70's Avatar
GD70
Default Re: Budget
Right now budget is low. Car runs good, power is just ok. My 04 Passat wagon with a 4 cylinder turbo (170hp) & 5 speed is quicker! Would the intake & carb I mentioned make a noticeable difference, or just a tune up? Don't have the specs on the engine rebuild.
GD
Old Jan 20, 2007 | 03:35 PM
Durango_Boy
GD
The intake and carb swap may help, but you really don't know what's in the motor at all do you? Maybe the engine building chose a poor lifter and cam combo, or maybe smog heads.
A carb and intake swap will only get you so far if the heads and exhaust are restricting flow, and if your cam has no more room.
Old Jan 21, 2007 | 03:12 PM
GD70's Avatar
GD70
Thanks for the advice. No..don't know what was done to the engine when rebuilt and the previous owner is being evasive to give me the name of the previous owner (a friend who wanted the car back real bad) who had the work done. I did have the valve covers off and it does have crane cams roller tip rockers. Frustrating to say the least. In the mean time I'll drive it as is and do what I can to improve power.
Some other questions: How best to align the headlights when closed. One is high and one is low about 1/4" at the fender surface and gaps are uneven. Very close at front and almost 1/2" at rear edge.
Old Jan 21, 2007 | 08:36 PM
GD70's Avatar
GD70
Just checked the engine today when it was completely warmed up. Pulled the air cleaner off and noticed the secondaries would not open when I pumped the throttle linkage wide open. What would keep them from opening? I suspect this may be why the power hasn't been very good. On the road the car is loud and I couldn't hear if they were opening. Wasn't hearing that glorious ROAR when they open.
Old Jan 21, 2007 | 08:38 PM
Durango_Boy
Just checked the engine today when it was completely warmed up. Pulled the air cleaner off and noticed the secodaries would not open when I pumped the throttle linkage wide open. What would keep them from opening? I suspect this may be why the power hasn't been very good. On the road the car is loud and I couldn't hear if they were opening. Wasn't hearing that glorious ROAR when they open.
It may be a poorly adjusted throttle cable, or something amiss with that carb.
Old Jan 21, 2007 | 08:40 PM
GD70's Avatar
GD70
I'll check the linkage. The carb is newely remanufactured and put on the car in september.
Old Jan 21, 2007 | 08:42 PM
Durango_Boy
Good luck...take pictures, and let us know what you find.
Old Jan 21, 2007 | 08:43 PM
ripen ls6's Avatar
ripen ls6
Originally Posted by 427SIXPACK
CONGRATS
Post some Pics
To Finally!
Old Jan 21, 2007 | 08:50 PM
GD70's Avatar
GD70
Thanks!
A few questions,
I discovered today that the secondaries are not opening under full throttle, why I believe the power's not what I was expecting? Why might that happen?
Second how best to align the headlights flush with the body surface when closed? One is 1/4" low and other 1/4" high, and both are too far forward, mot evenly spaced on all 4 sides.
Thanks, Glenn
Old Jan 21, 2007 | 08:52 PM
Durango_Boy
Thanks, Glenn
There are adjustment screws under the light assemblies that move it up or down. They can get them closer to what you want.
Old Jan 22, 2007 | 04:46 PM
FKING1's Avatar
FKING1
Thanks!
A few questions,
Thanks, Glenn
Had the same problem and found the throttle cable sheath was frayed inside preventing the cable from opening the secondaries fully. Also, cable may need adjusting forward in its mount.
Fred
