Gen Light won't turn off
Old Jan 27, 2007 | 09:20 PM
TimAT's Avatar
TimAT
The GEN light is controlled by the sense wire (on the 2 wire plug, 1 is hot all the time and the sense wire is hot with the key on). If the diode trio has a bad diode the light will stay on or glow.
If you're up to ripping the alternator apart, it's easy to test with a multimeter.
Same with the rectifier:
With the rectifier out, gently lift the brass tabs away from the posts. To test, use the multimeter and look for continuity in one direction across all the tabs. If you clip the black lead to the fins, 3 tabs will have continuity 1 way and the other 3 will show open. Reverse the meter leads, and the 3 open ones will now show continuity and the first 3 will show closed.
I forgot- the very FIRST thing that you should check- make sure the 2 wire plug is good. Lots of alternator problems are caused by a broken wire at the alternator plug!!
Rebuilding a SI alternator is no trick. Mark the case halves, 4 bolts and it comes apart, Changing bearings, brushes, diodes even the stator and rotor is easy. It's still cheaper to go get a reman, but
Old Jan 27, 2007 | 09:53 PM
Durango_Boy's Avatar
Durango_Boy
Yeah, that's a good call. Test the wires where they go into the plug into the alternator. Make sure both have 12V when the car is running.
