Step-byStep remove trailing arms?
Old Jan 23, 2007 | 03:56 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Default Step-byStep remove trailing arms?
IS there a thread for this? I searched a lot only found a couple bits and pieces.
Old Jan 23, 2007 | 04:06 PM
Durango_Boy's Avatar
Durango_Boy
PM GTR1999 - He'll be glad to help you, and his advise is top notch.
http://forums.corvetteforum.com/priv...o=newpm&u=2241
Old Jan 23, 2007 | 04:32 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
yes, I know Gary, and he knows his stuff....just thought there was a step-by step to print out.
Old Jan 23, 2007 | 04:37 PM
Durango_Boy
Jim Shae may have a printable paper on how to do that.
Old Jan 23, 2007 | 06:51 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
On how to get the arms off of the car? An archives search should turn up tons of information...it's one of the most asked questions on the Forums.
Old Jan 23, 2007 | 07:01 PM
Duke94's Avatar
Duke94
http://www.corvettemagazine.com/2005.../arms/arms.asp
http://www.corvettemagazine.com/2002...garms/ta-1.asp
http://www.corvettemagazine.com/2002...rm2/arm2-1.asp
Old Jan 23, 2007 | 07:04 PM
Tracker's Avatar
Tracker
Hers is a list of the most inportant things you need.
1. Lots and lots of beer.
2.A garage you can do a lot of swearing in and not be heard by others.
Old Jan 23, 2007 | 07:20 PM
Durango_Boy
I agree with the beer. Keep a few old tools handy too...ones you don't use. That way when you get pissed...you're not chucking your good ratchet across the garage at the wall.
Old Jan 23, 2007 | 07:52 PM
72LS1Vette's Avatar
72LS1Vette
And a SawzAll.
I took the nuts off the bolts on a bare frame and I couldn't budge the bolts with a BFH, and that was with plenty of room to swing. It's not an urgent project but the next step is to get the shims out and saw off the bolts.
Rick B.
Old Jan 23, 2007 | 08:03 PM
jlelec's Avatar
jlelec
Go buy yourself the following:
1. Your favorite Alcoholic Beverage (Plenty)
2. Lots of Sawz All Blades, Long Metal Cutting (you will ruin the centers, so it will take several per side)
3. BFH
4. Relaxing Music
5. Motrin for Afterwards (get enough for at least 2 nights)
6. Stool to sit on low to the ground.
7. Heating Pad (not required)
Its worth it when you get it done, your car will drive like new..
Good Luck! We are all here to help!
Old Jan 23, 2007 | 08:23 PM
texaswilkins's Avatar
texaswilkins
1. Jack it up and support it on several stands then cuss
2. soak everything with liquid wrench.
3. drink beer come back tomorrow
4. cuss some more then soak everything with liquid wrench.
5. drink beer come back tomorrow
6. take off tires, brakes and shocks
7. cuss a lot because you will find something else wrong now.
8. soak trailing arm bolts with liquid wrench
9. go inside where it's warm and drink another beer then call someone who has a shock mount removal tool.
10. take off spring and strut rods. This is only fun part because now you are pissed at your car and you get to beat the crap out of the shock mounts. You're gonna have to replace them anyway.
11. cuss even more because those spring mounts are metric bolts and are hard to find.
12. take a pin punch and hammer the trailing arm shims vertically so they come out of the rust holding them down. then pull them out.
13. have another beer you've earned it.
14. pull the shims out, undo the bolts and the trailing arms come out.
15. Go back inside and let your wife cuss cause she just figured out what it's gonna cost.
It's not real bad and I spent about 2 grand but I replaced nearly everything.
Bill
Old Jan 23, 2007 | 08:28 PM
72LS1Vette's Avatar
72LS1Vette
I forgot about the shock mounts! Better add 1 case per side. And maybe a laser weapon of some sort to loosen those things up.
Rick B.
Old Jan 23, 2007 | 08:32 PM
Durango_Boy
Rick B.
A green argon laser will burn through a truck engine.
Old Jan 23, 2007 | 08:49 PM
rcread's Avatar
rcread
VanSteel has a nice DVD, if you want to actually see how it's done.
Old Jan 23, 2007 | 09:08 PM
Durango_Boy
How much for the DVD and where can we get it?
Old Jan 23, 2007 | 10:17 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Sawzall and 8" blades from ACE.
Old Jan 23, 2007 | 11:59 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Cutting torch & a redneck to mis-use it.
To Step-byStep remove trailing arms?
Old Jan 24, 2007 | 11:00 AM
rcread's Avatar
rcread
http://www.vansteel.com/index.cfm?fu...&SubGroup=1912
$24.99 for the DVD. $19.99 for something called VHS. Whatever that is.
Old Jan 24, 2007 | 11:17 AM
CJ 77's Avatar
CJ 77
77/350- did mine myself to. I found a shop notes from ZIP, I think, and learned along the way. Spent some time at Boarder's Books reaearching too bucause I couldnt aford to buy them all. Being married I have learned to be verrrrrry patient. Biggest issues were pressing the new bushings in, removing the old, rusty, petrified U-joints from the axels (had to dril them out) and getting the arms out of the cavitys. The bolts and shims had solidified into (1) mass. Sawzaw & PB Blaster were key. Most important thing was patience. I'd get frustrated on the right side and go work on the left. Most corvette shops I talked to said that if I could pick a project (and it was the first thing I did to mine) that it was the worst to do.
Alignment although expensive was easier for the shop. Save any extra shims you have and take them to where you get it alligned. They may need them to make adjustments.
good luck
chuck
Old Jan 24, 2007 | 01:23 PM
michael c. volpe's Avatar
michael c. volpe
baaaaaad question here...................
i know of them, but what do they do, and how do they affect the performance of the car?
be gentle.......
