Leaking Break Caliper
Old Jan 23, 2007 | 07:34 PM
LBL C6's Avatar
LBL C6
Default Leaking Break Caliper
Why do brake calipers tend to leak after car has been sitting a month or so without being driven?
Is this something these old style calipers just do?
Mine has started leaking up front after not being driven for abour two months. Running down on the inside of the wheel and tire.
Old Jan 23, 2007 | 07:41 PM
LBL C6's Avatar
LBL C6
Default Brake Caliper Leaking
Why do brake calipers seem to leak after car has been sitting undriven for a while. My 81 has been sitting for about two months and the r/front caliber is leaking.
Old Jan 23, 2007 | 08:07 PM
Jims79's Avatar
Jims79
don't know why but they all do, I had to rebuild my rear after I purchased the car. the owner said its been sitting for 5 months..........lucky I didn't have to rebuild the front too....
Old Jan 23, 2007 | 10:26 PM
SIXFOOTER's Avatar
SIXFOOTER
O-ring calipers will fix that
Old Jan 24, 2007 | 10:31 AM
GaryZ's Avatar
GaryZ
If they have ever been honed even slightly, the fit will let the leak, or just old age. Dot 3 draws moisture, causes corrosion, pitting, rusting, I replaced mine at 24k, eight years ago, put in stainless sleeved calipers, new pistons, . All four were leaking, it was a mess. Put in Dot 5. Doesn't draw moisture. Haven't had any problems since. Worked for me. cheeerzzzzzz
To Leaking Break Caliper
