how do you like?
Old Jan 24, 2007 | 12:33 PM
panic's Avatar
panic
Default how do you like?
how do you like a touch of black among chrome bits and polished alu?
apart engine bay, i'm changing the color scheme of my '77 as well, from red with white hood/tops and wheels to matte black instead...
Old Jan 24, 2007 | 12:40 PM
75 Red Vert's Avatar
75 Red Vert
I like
Old Jan 24, 2007 | 12:46 PM
JPhil's Avatar
JPhil
Panic, are you going to paint the car "Black Denim"? I'm very interested in seeing that.
John
Old Jan 24, 2007 | 12:55 PM
panic's Avatar
panic
John
yes, matte black on hood (with a new sting ray scoop)/t-tops/minilite wheels. also interior will be all black (with red sparco's) and rest of the paint scheme same maroon red as now...
Old Jan 24, 2007 | 12:56 PM
moosie982's Avatar
moosie982
Looks very good to me but if you are not using a heater it'd look better without that hose,,, get a coupla plugs to block off the holes, Peace,,,Moosie
Old Jan 24, 2007 | 01:07 PM
panic's Avatar
panic
the whole heater sistem has been dumped sometime ago, the braided hose you see there was a 'temporary' (at that time) trick...you're right, it'd look a cleaner job as you advice with plugs to tap the holes, i've found them here...
http://www.speedwaymotors.com/Search...tings+%26+Hose
do you know what's the size needed for my application?
thanks/Giu
Old Jan 24, 2007 | 03:51 PM
noonie's Avatar
noonie
1/2 inch NPT
Even in Europe you should be able to find a plumbing supply or hydraulic supply with SAE threads. This is from Parker. Click worldwide link.
http://www.parker.com/EAD/displayCat...&sMode=Details
If blocking off heater line, make sure your bypass in the water pump works or you have bypass holes in the thermostat.
To how do you like?
