Paint Job
Old Jan 29, 2007 | 07:48 AM
Jaybird907's Avatar
Jaybird907
Thanks for all your advise. My Vette was a product of an insurance scam. The pervious own said it was keyed by his daughter. EVERY panel was keyed! So right from the start I know it would be more expensive than normal. I have very little experience with fiber glass, (worked with it a little bit on my boat) How hard is it to do the prep work? What is all involved with it? I would seriously consider doing these steps.
Old Jan 29, 2007 | 07:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mtwilsonboy
...but gun was sprating out little speeks of water is what it looked like. How could I stop that from happening?
Put a moisture trap in the line.
Old Jan 29, 2007 | 08:37 AM
2TONE82's Avatar
2TONE82
Just food for thought here...obtion B - sell your car and add the $5K - $6K you're going to spend on paint to buy a Corvette in better condition. This of course assumes you haven't spent a ton of $$$ on restoring your current car.
I did this back in 2002 ~ 2004. Sold a high mileage '82 that needed paint. I was quoted $7K for the paint job by two shops in this area. I can do most mech work on the car but know up front I don't have the patiance to paint a car. The car's interior was near perfect and I had recently rebuilt the tranny. But with over 150K miles on the car I needed to rebuild the motor, rear end, rear wheel bearings, suspension, on and on and on...you know the drill.
Long story short - sold the car for $7,500 and bought a near identical car (after a 6 month search) for $14,000. The "new" car, in and out, is an easy 8.5 to 9 and had less than 22K miles on her. If I'd had the old one painted I'd still have that long list of things to fix/restore...
Below is a comparision of the condition of the paint on the hood from the old and new car.
Here's a shot of the cars at the Plant. They are the same color, the old one (on the right) was made before digital cameras. Turns out the cars were produced about a month apart!
Old Jan 29, 2007 | 09:04 AM
Bangkok Dean's Avatar
Bangkok Dean
Now thats using your head
Old Jan 29, 2007 | 12:32 PM
Jaybird907's Avatar
Jaybird907
That's a heck of an idea. I may have to look into that. I have a good bit of work in mine already, plus I've been restoring mine custom. I just had all the interior done with ostrich skin and leather.
Old Jan 29, 2007 | 05:58 PM
72 LT1's Avatar
72 LT1
You could do all the prep work yourself and then pay/hire someone with experience to check your work and spray the material.
It took me about 40-50 hrs to get the old paint off the car, that's scraping and sanding over several weekends... I worked slow - professionals would be quicker but I'd still expect 20-30 hrs at $100/hr
That's $3000
Could be a great way to get a real nice paint job fo a LOT less!
Old Jan 29, 2007 | 06:54 PM
SuprJames's Avatar
SuprJames
Post pics of your interior. I'd love to see that!
I agree with those that said at least do the prep yourself. Use a heat gun and scraper to peel all paint off, and then scrub the body down with scotch brite plastic pads and laquer thinner. Took me about 40 hours to do mine and I didn't mess around. I'm doing a little more before I turn mine over to the bodyshop for rest of the bodywork and paint.
Old Jan 30, 2007 | 08:11 AM
Jaybird907's Avatar
Jaybird907
I'm headed home this weekend so I will snap some pictures and post them on monday. I haven't seen the finished product yet, I can't wait to see it. I had the the arm rest removed and installed a brushed billet pull bar. I am also installing Lokar billet door handels. As far as doing all the prep work, what pannles should I remove or would make everything easier if I removed them?
