another body work question
Old Jan 31, 2007 | 01:13 AM
babylonvette's Avatar
babylonvette
Default another body work question
i am starting the body work on my 72 i cut off the crashed tail panel and bonded on another using the west system ,epoxy resin/microfiberscame out good next i am working on the quarters to get rid of the bonding seams the chopped glass i usually use takes a whole day to dry. someone told me to use vettebond or fuser i am not familierwith either ? could i use tigerhairwith a drop of resin [polester]it dries in a few hours and is a little easier to sand, with the resin it fills the pinholes
Old Jan 31, 2007 | 09:06 AM
Artsvette73's Avatar
Artsvette73
I am not a body man but I wouldn't glass on the bonding seams. I used 3M Acryl-Blue Glazing Putty. Drys quick and easy to sand.
Old Jan 31, 2007 | 09:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I used regular mat over my seams and ended up sanding away most of that. A light coat of filler was also mostly sanded away. The area you're filling isn't very deep.
To another body work question
