Small Sat. Project Help
Old Jan 31, 2007 | 10:23 PM
randommj's Avatar
randommj
Default Small Sat. Project Help
ive got a couple SMALL problems with my vette and wanted to know of how to go about fixing them
1) the T-Tops are mis alligned and wanted to know of how to allign them
2)AND the "head lamp" light will never go off, i dont know wut it indicates bc mine has never worked but its unnder my "door ajar" light above my battery gague
if any one knows how to fix or replace (in the head lamp question) either of them i would greatly appriciate it!!!
randommj
Old Jan 31, 2007 | 10:43 PM
SIXFOOTER's Avatar
SIXFOOTER
The headlight switch is on the headlight assy. I think it is supposed to tell you the headlights are on but not up?
My t-tops are in the attic, dunno how to adjust them, be a while before thats an issue for me
Old Jan 31, 2007 | 10:49 PM
randommj's Avatar
randommj
would you know where the "sensor" is? or if i can fix it or replace it?
randommj
Old Jan 31, 2007 | 11:12 PM
big_G's Avatar
big_G
randommj
The switches that turn the warning light off are mounted on the headlamp actuator arms.
http://www.ecklers.com/product.asp?p...dept%5Fid=1171
Old Jan 31, 2007 | 11:17 PM
randommj's Avatar
randommj
AHHHH thank you! looks like ill b replaceing them when i get the cahnce! thanks again!!
randommj
Old Jan 31, 2007 | 11:27 PM
SIXFOOTER's Avatar
SIXFOOTER
Thats the one I was talking about. My 81 doesn't have them tho
Old Feb 2, 2007 | 08:49 AM
GD70's Avatar
GD70
This info came from "Steve COSD" when I asked a similar t-top alignment question. I haven't had the time yet to make these adjustments but will follow Steves advice.
The tops can be adjusted. You will need to remove the tops from the car. Place them upside down on something soft that wont damage the paint. You will need to remove the headliner. It is held on by small phillips screw and small plastic pieces that interlock to each other. These need to be pried apart with a flat blade screwdriver or something like a butter knife. If the plastic piece becomes unattached to the original postion then use some two part epoxy to reattach. After you get the headliner off then you will see what are called the spades. You will be able to see how they can be moved in or out to adjust as needed. Before you do any adjusting I would mark the original position. Also be aware that when you move the top in or out that it may have an affect on how the top of the door glass sits in the weatherstrip. If the gap is anywhere from 3/16th to 3/8ths and they are straight when looking while standing in front of the car than I would be happy. By the way I have seen the spades that have been bent by too much force or improper adjustment. After you adjust go slow when locking them in place.
Good Luck
Steve
Old Feb 2, 2007 | 10:02 AM
rihwoods's Avatar
rihwoods
Not sure...from pic's is it "height" at front on drivers side the issue ??? Center gap looks ok..
Rich
Old Feb 2, 2007 | 10:28 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
Paragon $22.00 , look from underNEATH YOU WILL SEE a bracket with a small bullit type switch replace it you can short the wires together and if the light on the db goes out you fixed it mine had the same problem. now fixed.
Old Feb 2, 2007 | 10:59 AM
randommj's Avatar
randommj
thank you so much is that on both lights or one "sensor" to both lights...and is that telling me that the lights are on but the door isnt up, or what is it trying to tell me?
Good Luck
Steve
AWSOME ill get to work on that once i get the vette back thanks SO much
Rich
i would like the center to much closer and the gap on the front of BOTH T-Tops is raised a little too much for my taste the back looks great height wise but still too far appart
randommj
Old Feb 2, 2007 | 11:28 AM
rihwoods's Avatar
rihwoods
randommj
I measured both my vettes center gap...the 78 is 3/8" and the 69 is 7/16"....if you are more than that,it may be possible to reduce gap...
Height may involve weather strip and/or forward latch...
Rich
Old Feb 2, 2007 | 11:32 AM
randommj's Avatar
randommj
Rich
my dads 72 is close bout 3/16 but my 74 is 3/4 maby a BIT bigger
randommj
To Small Sat. Project Help
