From: Minnesota in the summer, Las Vegas in the winter
I used the assembly manual for the doors on my 72. If I did not have any illustrations available to me and if the door was a mystery to me I would take the panel off the other door and study that one. As door innards go these are not too complicated. Be careful, the "while I'm at it" monster is in there........
The windows dont work. I am not sure if it is the motor or the switch or the harness.
Thanks to all of you who responded with advice.
I took apart the door parts. "While I am at it" I am going to paint the inside. There was a lot of rust inside. After a few hours of degreasing and rust fighting, the parts looks clean.
77/350- Wilcox has a downloadable "Door glass adjustment instructions 68-82" that may be of some help to you. Its under "repair help" and its free.
chuck
Also, use lots of lithium grease [tube type...not spray] on the slides. That will keep wear to a minimum. I'm assuming that you are replacing all of the plastic wear components.?? Looks like you are doing a great job so far.
77/350 - They look nice. How did you clean them up?
chuck
I sprayed soaked everything (except the motor) in rust remover for half an hour and then soaked for another half an hour in degreaser solution. After that I used a plastic brush to brush off the old grease. Washed and blow dried everything in the end.
I am thinking of cadmium spraying the rusted parts to prevent rust in the future.
The AIM will be your best friend for getting the door/window hardware reassembled. It also has the best procedure for adjusting the door glasses.
Be extremely careful with the door glass. You can lose a finger if that glass happens to fall unexpectedly.
Does the AIM have that kind of details about installation?!!
I purchased an AIM from corvettecentral. The reproduction/copying was extremely bad and I can hardly read anything. Besides it does not have any instructions or procedures detailed out.
No & yes. You're doing a good job, so why not go all the way & make sure that you'll never have to pull it all apart again due to corrosion? The insides of the doors are notorious for rot, so anything that stops it is a good thing.
Regarding the post title (Sitting ray), I vote that any Vette undergoing any sort restoration/fix is henceforth to be known as a "Corvette Sitting Ray" until such time that it's back on the road
And you may print and stick this emblem temporarily...
